Buick Enclave Air Noise in Steering Wheel
                    Our enclave is a month ols and we can hear the steering wheel which sound like air if you put your ear up to it.  We checked out another new enclave on the lot and it had the same noise but not quite as loud as ours.  Ours seemed like it got worse after we had 2 front struts replaced.  Anyone have a sinmilar issue?
BTW, the power steering failure came about 5 weeks after the water pump failed and we lost ALL cooling fluid before we could get the car home.
I am from GM Customer Service. Can you keep me informed if the part doesn’t come in by the end of this week please? You can email me at socialmedia@gm.com Thank you,
Mariah GM Customer Service
On Thursday April 29th I was driving to an evening meeting when all of a sudden my Onstar system dialed Onstar Emergency. I had not touched anything! After explaining what happened to the lady on the other end the call was ended. 2 minutes later it did it again...and then again...and then again. After about 6 calls to Onstar Emergency uninitiated my me they connected me to Tech Support. They ran a diagnostic and said that "button # 3 was showing an error and it appeared to be a wiring fault". I took the car in to the dealer on Friday April 30 am...they confirmed the same as Tech Supt. and ordered a mirror assembly but could not provide an ETA.
On Wed May 5th I called the dealer because the power steering was "grinding and squeeling" again to arrange to bring it in and see if the mirror was in. It was. The mirror assembly was replaced and fluid added to the power steering...supposedly they cannot get all the air out of the system when the work is done... the fill cap has a vent to allow air to escape and therefore the fluid was low.
Friday May 7th the power steering started to "grind" again. Saturday it was louder and by Sunday it was squeeling like a pig! I checked the power steering fluid level...it did not even register on the stick!! Then I noticed power steering fluid on my garage floor (I had not paid attention before as I thought it was condensation from the air conditioning). So Monday May 10th back to the dealer...it is still there!
So, since this is a lease vehicle that I had planned on buying at the end of the lease. I am now looking to end the lease early with no penalty and find myself another SUV like a BMW X5!!
:mad:
I am from GM Customer Service. Have you spoken to the dealership since the fix and explained that the noise concern still exists? Thank you,
