Propeller-like Sound while Driving the car
                    I have a 2001 Cadillac Seville STS with 91,000 miles. Recently, while 'driving' the car there is a propeller-like sound that comes from the front half of the car. This sound comes up (or is audible) after the car is driving above 15 mph. The sound frequency/pitch increases & decreases with speed variance. Higher the speed, the more intense is the sound pitch. (It is somewhat similar to putting a card against the spokes of a bicycle and riding, except the sound is more like a propeller of a toy remote airplane).  However, when the car is standing idle and I rev up the engine even to high rpm, there is NO sound. It comes up only when the car is driving. I ran the in-dash diagnostic and the problem code ABS C1287 came up, which perhaps is not related to this sound.
Any idea what the problem could be? Will appreciate your feedback.
The motor mounts rubber exterior deteriorates, and then the oil leaks out, and then the mount does not stop the motor from torquing sideways, so the motor moves too much now, and the noise you hear is the engine grinding against other parts of the car, a vibrating noise, sort of propeller-like, if you will, under load. Once you are moving and the engine torque is minimized, the grinding and noise are non-existent. Get a $1000.00 bill ready. Why do Caddys have oil-filled motor mounts? Because that's how Caddy engineers designed the mounts to that the engine torque is so controlled and smooth and this translates into exceptionally smooth shifts between gears. No clunking as the engine torques through rpms. Great smoothness, but great repair costs. Isn't it just fun to drive a Caddy? I thought so too.
I recently purchased the above mentioned vehicle from an estate sale dealer, but no one knows how the security key pad is armed??
I have a two page booket on the V-100 SYSTEM,IT DOESN'T TELL ME HOW TO ARM THE SYSTEM WITH THE KEY PAD?
The booklet does tell me how to try the PANIC mode and it works, as to setting up the system ,how do I arm it if I don't know what numbers the deceased prior owner used.
The alarm key pad is currently not activated -no red light-when I open and close the car doors ,nothing happens maybe I should place my own 3-digit numbers into the keypad and see what happen-any assistance would be appreciated!!
RM2816
Al S
