Nissan Rogue Tires and Wheels
in Nissan
I have a 2008 Rogue and need some information.
1. What is the proper way to protect the Alloy Wheels? Any product to buy to keep them looking new?
2. What is the best wax to use on the Rogue? My brother said to use Turtle One Step.
3. What is the best scratch remover?
If anybody does a tire swap to another brand and it quiets down noticable please post your results.
thanks, Ron
I'm pretty fussy and hard to please with cars [and other things]. I bought the Rogue for my wife but, I find the more I drive it the more I love it! I want to trade my pickup in for one now!
BYW, I have the continental tires. I find no appreciable difference between any other riding tire.
Tire Rack
What does it take to get this thing to turn off ? My son has a new Maxima and had the same problem. The dealer offered to 'fix' it by filling the tires with nitrogen (for $20). That tells me not to take this car to the dealer for service but doesn't solve the problem. I'd just turn the thing off if I knew what wire to cut.
Anyone else had a problem with the tire pressure monitor?
PS: you did say "a little softer", I'm not sure if you went to extreme pressure drop...I never tried that.
Interesting explanation. The dealer told me something different. They said there is a setting that determines the least amont of pressure that is OK. Below that the alrm lights up. Mine was set to 38lb. All my tires were at 36lb (I checked more than once) and the indicator was on. They reset the limit to 32lb and now the light is off. To test the two explanations you might lower yours to 30lb and make sure they are all equal then see if the light comes on.
"PS: you did say "a little softer", I'm not sure if you went to extreme pressure drop...I never tried that. "
RKoko
Took delivery on my Rogue at 19 miles on ODO. Tread depth on Contis was 6,6,6, & 7/32!!! Won't go far on that. So upgraded to Avids for that and other reasons. 16/32 at install. Much quieter at Interstate speeds. Much smoother at slower speeds. The CVT vibration is noticeably less at slow speeds. dealer gave good trade on the OEMS.
Would appreciate feedback as to where I might locate same.
You can only purchase online on their website.
I discovered it by doing some searching on the web. I kept running across their name on different sites as well as this one. Check them out, they have a ton of pics on their site.
:shades:
Good Luck, Ron
Anyone else replace their Contis?
Avid TRZ 225-60 17.
10,500 miles on them, not much wear. Fine wet traction and OK (within limits) on wet snow and light ice. So far they seem to be a fine tire: Much better wear than the OEM Conti Contacts, and MUCH better traction, braking and cornering. Also much quieter on the highway.
HTH
I'm not a fan of the Conti Contacts--not a lot of tread out of the box--but they've worn ok. Granted, I rotate them regularly and make sure inflation is good, and drive pretty conservatively. I've got over 46K on them and I think they're good for a few more months, maybe even til the snow flies.
I can't find my owners manual and was wondering if anyone knows of the recommended tire rotation pattern for a 2009 Rogue S SUV.
I'm thinking it must just be front to rear as you can't cross radials (have to turn in the same direction).
Sammy
Tire Rotation Instructions (Tire Rack).
You can download a free manual and check what Nissan recommends for your Rogue. I'd be curious to see if an X rotation is not recommended.
How To Find Your Car Owner's Manual Online
So, I was searching online and for the price I can afford my options are:
1. BF Goodrich Long Trail T/A Tour ($/547)
2. Yokohama Geolandar H/T-S G051 ($/445)
3. Yokohama YK580 ($/475)
Does somebody over here has an opinion about these tires on the Rogue AWD or could you recommend another one.
Thanks for any help!!!
doest any one has a suggetion to me.
What the dealer say could cause that problem??? Does happen on all 4 tires??? Get an opinion from an authorized and certified tire service company and if they said it could be something defective go to The Dealer, Nissan and BBB.
Good luck, keep us posted please.
My wife drive almost 1500 miles a month, tire were purchased in December so right now she drove over 5000 miles, feels and looks great.
But it could also be the result of .... ah .... Mmmmm ... let's call it "Spirited" driving.
I have a Rogue SL AWD and I'm thinking about putting 4 new Destination A/T, but they are 235/65 instead of 225/60...do you think these will fit?
So...anyone have an opinion as to what I should do? My options are:
- buy a different brand of 18" all seasons and hope my mechanic's wife is mistaken
- buy 17" tires and rims and pray for better winter performance
- keep the crappy (and LOUD) tires I have now and buy WINTER tires and rims
Thank you in advance!
Second, snow traction is highly dependent on the amount of wear on your tires. More wear = less traction.
And lastly, even the best winter tire is going to have less grip in snow than the worst all season does on dry pavement. In other words, don't expect winter tires to solve all the traction issues.
Your mechanic's wife doesn't really know tires. There are some tires with some decent snow traction available in your size. You will need to spend some time researching this to get the compromise you want. There is quite a lot of variation in treadwear ratings and traction.
Go to Tire Rack and spend a bit of time. That will help you sort this out.
I have researched the living hell out of 18" tires on Tire Rack and a host of other sites...even went so far as to buy a set of new 18" tires, but I was told I wouldn't be happy with them either due to the fact that they were the same size tires as the tires I hate, so I returned them. I realize winter tires are the way to go in winter weather...but I am trying to avoid having to buy 2 complete sets of new tires (winter tires and rims and then whatever size all season tires I decide to get). I just don't have that kind of money at my disposal. Luckily, I have several months to figure this out. Thanks again!
