Help me understand these Buick Rendezvous repairs!
We just bought an '05 Rendezvous and have the service records, but I have no idea what the parts are that were repaired.
This is the list:
hoses, power steering hydraulic-return
harness, wiring-engine complete-replace
wiring and/or connector-fuel system
throttle body assembly and harness
throttle position sensor
wiring and/or connector-emissions system,
powertrain control module replacement
cover and or gasket, camshift housing right
lever, detent-replace
If anyone has had any of these done, or if they know what they are and why they would need replacement, I would appreciate a reply.
Thanks for any info you can provide.
cloverboy
This is the list:
cloverboy
The dealer said the head gasket they are not sure of and would only be able to tell once they get into it. I also have a groan when making tight turns such as in a parking lot or sharp corner. Also now my fuel tank doesn't register how much fuel I have. I use the trip gauge. I am so upset. I still owe money on this vehicle. I called the general manager at the dealer regarding this, but he returned my call and I wasn't home, he did give me his personal number. However, I have returned his call 3 times on 3 differant days and no response. I then called the buick 800 and they gave me a case number and I should hear back within 24-48 hours. I was so mad that I called the bank and put a stop payment on my check, maybe now he will call me back. I will pay them for the repair, I won't stiff them, but they could at least call me back and tell me no or whatever. Am I off base on this. From what I'm reading I don't think so. Any advice, would be appreciated. I can't sell this car so I need options?
For the groan you hear, if you have the AWD version it is likely the versatrak fluid either needs changing or there is a leak causing low fluid level.
Rose
This car is a nightmare, has cost more than all my prior four cars combined since I bought it used in 2004.
No extended warrenty, and dealer said nothing they could do to help, althought they knew I had excessive repairs on this, the Buick rep also said tough.
GM paid half and I paid half due to it being an internal problem.A0 The dealer will probally try to get out of it but due to the mileage at the time of my car problem like 75000 they would only do half.It was better
then paying it all.Also there was a problem with the antifreeze leaking
they repaired that for free it was a 500 dollar repair...Both were factory
defects....I do have a contact at GM that helped me with the dealership if
you need it I had to stop payment with the dealer before they finally had the owner call me to explain my situation.Mine runs great since.
Good luck.If I can make them do it anyone can..Menopausal Rose
Bewary of garages many are rip offs and their only concern is taking your money. Do your homework!
I noticed when turning into parking spaces or making tight or U turns there is a groaning sound coming from the front wheels,manely when the outside temp is 80+, I took it to my mechanic and he told me there was a service tech bulletin on this problem and was told the fluid is breaking down and needed to be replaced, he said they told him he had to drain the axle fluid and after you replace the fluid you have to drive it then drain it again and replace again, this stuff is $38.00 a quart and he said I need 6 quarts but I can't believe you put $100. of fluid in then just put it down the drain ? Has anyone heard of this problem ?
TSB 1835 or
TSB 01486
The AWD drive system growling on sharp turns is a known problem with many GM Vehicles. For example, Venture Rendezvous Silhouette Aztek Montana Uplander Terraza, etc..
For more details, read the many posts within: http://www.aztekfanclub.com/SMF/index.php?topic=2490.15
Note: Scroll down the page for its discussion.
Bottom line... Sounds like you need to "flush / replace" your vehicle's AWD Fluids. This "most often" eliminates the growning sound. Hopefully, it eliminates the growling / growning sounds in your GM vehicle as well.
Hope this helps - some how...
Thanks again, Richard
Intake manifold gasket...$1,100
Driver side Window Regulator
Driver side Window Motor
Driver side Window Regulator Clips.....total $170
Front Wheel Bearing Assembly....(repaired both front assemblies on separate occasions - this is simply a horrible part)....total $3000
Water Pump......$350
Thermostat.......(replaced twice)....total $615
In addition to the repairs listed above, we live with a constant electrical problem which plagues this car. It will sometimes fail to start or will lock and unlock the doors for no reason. I once had to disconnect the battery in order to force the car from repeatedly locking and unlocking the doors. However, by that time, the batter was drained to the point that it needed to be recharged.
This is simply a horribly designed vehicle. I hope that anyone considering buying a GM car will think twice before putting good money into a GM money pit like this one.
:lemon:
I have had all that, except for Front wheel Bearing, but incl the AC, $2000, and both tie rods, 400+, both front window motors, and at 96,000 miles the head gaskets started to leak. My dealer forgot to mention that on one repair, so at 104,000 miles the heads exploded near Bowling Green, KY. I limped backed to Lex and had the dealer repair that for $3000.
Now the AWD is disabled and the Power lock breaks light is on, another 700$+ and the gasket around the bottom of the motor is leaking oil. Oh, and the hood is bubbling with rust. I am broke, so this puppy will just have to fall apart now.
Has 137,500 miles now and worth about $4000 maybe.
It has one darned good sound system for my opera tho, helps keep my sanity. :mad:
The repair list I have on my 06 Rendezvous has grown to the point that I've spent more on it in repairs than it cost to buy. Dump it! Ditch it! It will put you in the poorhouse. :sick:
I HATE MINE SO MUCH I REFUSE TO DRIVE IT ANYMORE. :mad:
I have less problems with the 1990 Jeep we have. :shades:
If wondering, my wife has a "used" 2003 FWD RDV (2nd edition of 2003). So far, we've only needed to replace its front wheel bearings and its 2 x front brake rotors. Being a heavy "front end" vehicle, it loves chewing up wheel bearings and brake rotors. These are well known weak design problem.
For far at 74,000 Miles, our 2003 FWD RDV is running great. No problems with its intake gasket (then again, we do replace its cooling fluid every 3.5 years) and its transmission is working great as well. We were going to install a Trailer hitch on it and my local "trusted" auto mechanic said, "NO way - if you do, you'll kill it". To him, this specfic heavy weight Cross-Over vehicle has barely enough power and strength to pull (and stop) itself. Having an attached trailer, extra weight of AWD system (if we had an AWD system) and internal heavy cargo would immediately over stress this vehicle. Thus, blowing its intake gasket, its head gaskets and other "under designed" parts. Thus, our Class III hitch is now sitting in our shed - which is a great thing in the long run...
For our 2003 (2nd edition) FWD RDV with 3,4L engine, we drive it like a weaker design vehicle (re: never make it over stress in traffic or up hills) and let it drive us around in comfort. And we never "push it hard" on extreme hot days either. So far, my wife's 2003 FWD RDV has been treating us great.
Sorry to hear your 2002 AWD RDV is giving you problems. If it were me, I'd probably sell your heavier weight 2002 AWD RDV cross-over vehicle and get something more reliable. Especially if you need its AWD system and/or use if for aggresive driving (or heavy weight transport needs).
As far as the anti-lock breaks...I never had that issue so they both may be unrelated issues.
More for the anti lock break.
Now the car is jumping and bucking like it is not firing, so must be the spark plugs I hop. Sucker is still leaking from a seal and I can't afford to repair any of it.
I am hoping it will self immolate on the road, as it is probably only worth 3500$ and I have over 11,000 dollars in repairs in it since 2004. I could have bought a H :mad: ummer.
I apologize that you have had concerns with your vehicle. I would like an agent to look into your concern further. Can you please email me your VIN, contact information, dealership and best time to contact you? You can get my email by clicking on gmcustsvc. Thank you,
Mariah GM Customer Service
these cars are brutal!!
Boy you have a full time job answering this Rendezvoodoo board.
I will send you what I have. Thank you.
Julia Mitchel, Lexington, KY :mad:
I didn't know that you don't have the vehicle anymore. I received your e-mail before I saw that you posted back. So my e-mail will be addressing your old vehicle, sorry about the mix-up.
Thank you,
The AWD and Power Lock light was still on when I traded the car in last week.
There were no recalls on the AC, I said the Dealer in Grainger, IN fixed it in 2005, he fixed it for $2000. The first of my expensive problems with this GM vehicle that was made in Mexico.
No wonder American's have no jobs, thanks to GM.
I apologize for the concerns you had with your vehicle. Because you have traded in the vehicle there is nothing I can do. I apologize for the inconvenience this may have caused. Thank you,
