2004 Chevy Blazer Trans. Fluid Dipstick
timmerhyll
Member Posts: 3
in Chevrolet
The trans. fluid dipstick is stuck and no amount of pulling or twisting is dislodging it so I can check the fluid in my 2004 Blazer. Any suggestions?
Example of the grease monkeys at fast lube establishments:
I was in a hurry to change the engine oil and filter on my 1991 Chevrolet Blazer 4WD so I took it to a fast lubrication establishment and had it done. I immediately went home and was going to replace the oil filter they put on and install a special high quality oil filter that is never sold at fast lube garages. No amount of twisting by hand or even with a band type oil filter wrench could dislodge the filter they installed. I took it back to themn and told them to loosen it. They tried and the manager came to me ans asked "Who put that filter on anyway?" I said "You did! And I want it loosened.! They finally go it loosened enough where I could replace it with my higher quality special oil filter.
I explained to the fast oil change garage manager that the higher quality oil filters have red silicone rubber gaskets and only need to be hand tight. Older and poor quality oil filters use black nitrile rubber gasket which is prone to shrinkage and hardening.If you cannot remove a oil filter by hand, it was previously installed too tight.
2nd great will not engage. Rest of gears
Shift ok...it a automatic.
What would cause this.?
