Nissan Frontier Electrical Issues
The speed odometer stopped working on our 1998 Nissan Frontier Pickup. Any suggestions on what the problem might be and how we might be able to fix it?
dee
dee
I called a Nissan service rep, and he told me that I would have to pay $90 just for them to hook the scope to it, but he thought it sounds like the sensor located in the gas tank has gone bad. After reading all the other people with the same problem, it sure sounds to me like Nissan needs to look at this problem.
Has anyone else had this same problem, and did Nissan take care of the problem for free?
TSB: NTB07069 - Fuel gauge is erratic, inaccurate, or inoperative. And/or The MIL is "ON" with DTC P0461, P0462, or P0463 stored in Self-Diagnosis. Replace the fuel level sending unit.
It's not a hairy fix. They drop the fuel tank (they ask you to come in when it's near empty to lighten it up) and replace the fuel sender and I think there's a guard in there they need to replace too. Good luck.
You can find it by doing a Google search on 'NTE152 Nissan'
The link described the replacement of two transistors. When I inspected the transistors on my circuit card, the transistors measured OK, so I didn't replace them. What I discovered is that the solder joints were cracked, so I resoldered them and reassembled the gauges. Low and behold - everything worked. The problem is that they used cheap PC boards that were single sided without plated through holes. Over time the solder joints crack on the power transistors and the gauges eventually stop working. They probably saved 100¥.
Fortunately, both times it was parked in my yard and I was able to go get the spare set of keys out of the drawer and unlock it.
It's a bit unnerving, though, thinking that this could happen someplace remote where a spare key isn't handy. :confuse:
http://www.pbase.com/lookoutranch/image/140696910.jpg
SE V6 6-speed manual transmission, 4WD
