Saturn S-Series Brake Problems
This morning the button on my brake handle popped out. Any DIY fixes for this? I will be taking it apart and looking at it asap but wondering if anyone else has had this happen.
Thanks-
Thanks-
New 02 sensor new egr valve EGR solenoid is next........,All else is normal idle mpg
pwr warning lites etc..
First the mechanic said it was my ABS sensor unit and it was shorted out and said I could drive safely without it.
Drove it home and noticed the brake pedal now went to the floor and the emergency brake was real easy to pull- no resistance.
Back to the shop....THEN he said they found it was the ABS sensor unit leaking into the master cylinder and causing it to fail. My questions are....
1. Is it possible for the ABS unit to leak into the master brake cylinder and cause it to fail?
2. Could the master brake cylinder failing cause the ABS light to come on?
3. What else could cause the ABS light to come on?
4. Would doing a computer diagnostic test check both the master brake cylinder and the ABS unit?
5. Could the computer diagnostic test cause failure of either the master brake cylinder or the ABS unit?
when pushing on the brake while car is in motion ? Brakes seem to operate just fine. :confuse:
What did you find to be the root cause of your brake pedal problem as it sounds similar to mine. Thanx, Jeff
It is currently at the dealership being repaired, to the tune of almost $3,000. They tell me this is rare and can provide no cause or explanation. The left front and right rear brakes froze on and caused a fire in the wheels.
