Saturn S-Series Heating / Cooling
in Saturn
The temperature control doesn't change the air temperature on my 94 SL2. If I slide the control all the way to the red, the air blowing out doesn't get any hotter. If I slide it all the way to the blue with the AC button and the recirculating air buttons depressed, it doesn't get any cooler.
The blower fan works fine, the AC is charged with refrigerant, the compressor looks like it is working, and all the related relays and fuses seem to be okay. I've taken the radio out and loosened the heat/air control. The cables for the vents and the temperature are both attached. Maybe the temp control cable is broken down the line somewhere.
What else am I missing that could cause this? Something simple I hope!
Tracy
Tracy
