I am in NY, however, and would like to use them. I have tried all lighting switches, and can't get them to come on. Is this something a dealer has to tinker with, or is there a switch or action I am missing?
Thanks for any comments.
ETM
Second, there is no DRL for US model, AFAIK.
Usually the wiring is different for the headlight. DRL uses 1/3 brightness of far lights.
I may ask dealer if he can somehow duplicate the DRL used on Canadian issue vehicles; can't imagine it could be that complicated.
Tks
ETM
I will make sure I pass on yours next time.
That has been corrected.
SUVs and Smart Shopper
You jumped to conclusion. The original post was in a wrong thread. Tidester (our host) created this new thread for it. I stand by my statement. I am very mature.
I merely pointed out his error and provided info as much as I know. He didn't even apologize for it. Who was inmature? Me?
~Chris
I had Hidden Hitch I purchased from etrailer.com.
On Youtube, you probably could find a video of installation.
If not, go to etrailer.com search for "MAZDA CX9 Hitch".
They have a video. The installation is easy if
(1) you have another person help you hold it up
(2) you have jack stand to replace (1)
A torque wrentch is highly recommended since you need to tighten it to 75ft-lb.
I will used it for bikes also.
Thanks again,
~Chris
With 2009 models, you actually can now purchase OE hitch (class II). The OE hitch opening is positioned higher through the rear bumper (OE bumper has a cut-out mark looking from inside to cut out for the hitch). You can find one on eBay.
The downside is that the OE hitch is much more expensive, but it integrate more nicely with the bumper. Just a thought. That was not an option in 2008. i.e. I had no such choice, then.
For synthetic oil. It servces several purposes
- it endures heat better. Good for those who bring their vehicles to the track often to race in high speed.
- it lasts longer w/o breaking down. Good for longer interval between oil change (say, 10K-15K miles). However, the oil cost is 3X higher than regular one. Therefore, you don't really save much $$$ that way either.
- it lubricates better especially at cold starts after long period of parking. How often do you do that?! If you change your oil regularly (say every 5000 miles) your CX9 engine will last long enough. Your transmission probably will fail before your engine does....
So, you decide whether you need synthetic or not. It is your money and your CX9.
Some poeple baby their CX9s more than other.
Does this hitch go below the bumper?
and if so, does it lower the rear height ie can you
accidentally bump this on a steep drive?
Google the image "CX9 Hitch" and you will see at least one picture.
The picture is from an installation video at etrail.com.
You can find the OE installation at here
www.mazdaparts.com -> go to CX9 and see the accessories.
However, the OE one is 2 1/4" while the aftermarket only carries 3".
To each one's own. I like the 3" opening.
Please forgive my ignorance. When you state that the wiring should be at the rear end, do you mean under the car and if so, what should I be looking for?
Take out the two little pins holding it in, and the entire compartment comes out..
Then look under the harness against the body, sort of underneath the tail light... its a 6 pin white connector taped to it. You can use a voltmeter with ground on the black pin, and map out the remaing pins (tl, tr, brake, running lights, etc)
If I have a 2008 AWD CX9, and I get the tow added at the dealer, is this an after
market hitch and hence, 3" below the bumper?
Mazda dealer says he can install the hitch and have it covered by Mazda. Does
this mean his will be through the bumper or below it? I can presume it is after market and hence below the bumper?
zippy
No one can add the tow "package" which includes
- heavy duty radiator
- dual fan control modules (instead of one) - look for a silver module with heat sink about 2-3 inches in size near fan. CX9 has two fans. The one with Tow package (real OE one) has two fan control modules.
- heavy duty transmission cooler
- ECU programming revision - change gear shifting points and and stability control algorithm to counter trailer swinging.
- hitch and wiring
I am guessing that your dealer only gives you the factory hitch and wiring.
(i.e. for you to tow 2000lb or less only)
The factory hitch sticks out at the lower part of the rear bumper (better integration). However, it has 2 1/4" inch opening. Most after-market hitches available for CX9 have 3" inch opening.
Depending on how you plan to use your CX9, a full-blown Tow package may not be best for you unless you need to tow more than 2000lb. Those changes with Tow package could slow down the performance of CX9 or decrease MPG (a tranny that is too "cool" may increase MPG slightly). The gear-shifting algorithm could also costs you MPG as well. Just a reminder that it's not "the more, the better".
All FWD CX-9 come standard with a towing capacity of 2000lbs. In order to tow to this capacity you will need to add a tow hitch and wiring harness neither is which is available from the factory but is available from the dealer.
All AWD CX-9 come standard with a factory tow prep package which consists of a larger transmission cooler, revised ECM and wiring harness. With this tow prep package the towing capacity is 3500lbs. In addition, you will need to add a tow hitch which is not available from the factory but is available from the factory.
The FWD Grand Touring CX-9 does have a factory towing package available which includes the tow prep package metioned above plus a tow hitch. This will allow towing to 3500 lbs. However, in order to get the towing package you also need to order a "mandatory" GT assist package.
The towing prep package cannot be installed by the dealer only the factory.
The factory tow hitch which is available for the dealer to install, is a class II (3500 lbs) hitch with a 1.5" reciever.
I am getting a Class III hitch installated so I can get a 2" reciever for which I have a bicycle rack and other towing items. I do not know how it will integrate with the bumper but I will let everyone know.
Don't reply that some literature or someone told you something else. This is what I learned over a 2 week period proir to purchasing my CX-9.
I hope newawdcx9 was not implying that I provided wrong info. Because if I did, I certainly would love to know and correct it in my head.
I have a 2008 model.
newawdcx9 seems to know more about 2009 models.
(Except when conversing with his wife)
That way, you get what you want, and have an Sirrus unit (for the dealer as parts) or for you to sell it on eBay. Make sure you have the whole accessories of Sirrus if you want to sell it on eBay.
Depending on your negotiation with the salesperson, he/she may or may not charge you for the labor cost (get behind the center console and reconnect wirings).
all 2009 AWD (Sports, Touring, or Grand Toruing) models have Tow Prep as standard. No so for 2008 or 2007.
My 2008 did not come with Tow package.
Here is a thread you may follow or ask question.
http://www.mazdas247.com/forum/showthread.php?t=123674480&page=3
Or can I go with a generic harness like this for $25 and tap into the wiring harness mentioned - http://www.etrailer.com/pc-VWH~20251.htm
Or just the $5 harness here http://www.etrailer.com/pc-VWH~18002.htm
