GM Extended Warranty Question
I have an '06 Suburban on which the original factory warranty will expire in about 90 days. I am researching the extended warranty market and
would like to know if anyone on this board has purchased a GM extended warranty and if you have had any problems with GM warranty repairs. Any input on any other warranties would be welcome. I will be buying something in the 5 year/50,000 mile range and want full coverage and no more than a $200 deductible. Thanks for any info you can pass along.
Its a kind of conflict of interest to have people diagnose and supposedly fix a vehicle that you pay warranty to, isn't it?
Arrie
Wow...I just took another look, if you have less that 24000 miles on your Suburban you might be in luck... 60 month/50000 mile coverage for that is only $1130 w/$200 deductible.
Paying $21000 for a '06 with 34 000 miles IS WAY TOO MUCH!!!!!!
You can get '08 with only 10 000 - 15 000 miles for about $25 000.
But if you like your '95 why spend money for a newer one? If you care to read this forum under all topics you might not want to buy a newer one anyway.
Like I said "The Queen Mary" could be far better, and in all honesty I believe it is much better quality vehicle that the newer ones. And don't even think spending money for any kind of GM extended warranty. They don't fix their vehicles under the factory 3 year 36 000 miles warranty either. Why would they do it under extended one?
My advice to you is simply keep what you have. The worst case for you is that the engine and tranny go out. Well, have not seen many posts of tranny or engine going out in your vintage car. Have seen many trannys go out on very late models. Engines not but then there is this coolant leaking inside the engine problem.
You can put a new engine in your car for about $ 3000 depending who does it. Tranny cost about the same or less. Worst case you talk about $ 5000 - $6000 investment on your vehicle.
BUT, you only have 95 000 miles. Your engine is less than half way for normal wear and tear. Of course sh.. happens but when US car makers used to know how to make an engine it would go 1/4 million miles without problems if you change oil at required frequency. And guess what, the new ones do not give you any better gas mileage either.
Just keep what you have and fix it when it needs it. For the engine I think you are just fine and I would not worry about tranny either. Just change the transmission fluid as you are at 100 000 miles. Next thing to go probably is the drive shaft, which cost less than $150 to fix at the dealer.
Arrie
____________________________________________________________________
Keep the '95....it is a much better built vehicle, especially the engine and tranny. And that $4K for a GM warranty is outrageous. You can get a good indie aftermarket warranty that covers everything you need for around $1500 for 50K miles/5 years. But again I say....keep your '95. It should be good for at least another 100K miles.
1. transmission repaired twice. $2500 total
2. heater blower motor and actuators. $975
3. cd player died $450
i paid 1150 for the warranty 0 deductable and it saved me $2825.00 .....get the warranty
What kind of repairs were they?
SUVs and Smart Shopper
I hope I need to use it to see if I needed it and hope I have no trouble.
What is the experience with GM's extended warranty. In the past I have purchased the Honda Care extended warranties which were an excellent deal. Extends the original warranty. Is GM's the same?
Thanks for any thoughts...
