Visitor Agreement.
I did find info, and a video, of a Mazda engineer explaining their "internally designed and highly advanced active torque split system". Don't confuse the similarities between all F/awd systems with being the "same" system. All F/awd use a PTO, tailshaft and some form of rear differential control system. There is no way Toyota could be using the same system without buying it from Mazda and that isn't very likely.
As for having cooling to the PTO... hmmm, I'm a bit surprised Toyota doesn't do it. But, perhaps it's because Mazda couldn't get theirs to keep from overheating? A lot of other F/awd designs do not have cooling as well (BorgWarner for one). All I know on that topic... but, seems like cooled would be better than uncool
"...buying form Mazda..."
This new F/awd system may well have been developed by one of the transmission company's, independent of a single marque. I note the Porsche has now adopted the very same technique except for it being used for R/awd.
"..Mazda couldn't keep theirs from overheating..."
No, historically it was Ford that couldn't keep the PTO/ATC from overheating. Ford reacted by revising the firmware such that the driveline windup stress was significantly reduced. Apparently Mazda wanted to keep the full F/awd functionality and therefore added the cooling.
It will be interesting to see how functional the Venza F/awd system is vs the RX350. I strongly suspect Lexus will soon either eliminate the PB for manually engaging the rear drive or add PTO cooling. Easier to revise the firmware once they discover that most driver's, even Lexus driver's, haven't a clue as to when to use, of not, the manual mode.
This week, I purchased new hub centric rings, verified all 4 wheels were balanced (Road Forced balanced by Gateway Tire) yet, around 60mph, it shakes like I am going over bumps that shakes the entire car. Then around 70mph, my steering wheel starts to shake like the freaking wheels are out of balance!
I have spent money and time and I am out of options. I took it to the dealership and like you and I already know, they can't do crap because of the custom wheels on it. I know for a fact that I am not the only person who has custom wheels on their CX-7. I don't have another set of wheels to put on to see if it does the same with other wheels.
I think it is something other than the wheels because of the really bad shaking and I have noticed when I hit a bump, the wheels sort of feel loose in a odd sort of way...Anyone witness any of this and did you find a resolution??? :confuse:
Shannon
I purchased a 2010 Cx 7 (non Turbo), I replaced factory 17" wheels/tires, with OEM 18" spec tires, and wheels. I have had numerous balancing,tire rotations, still has vibration. I have 5K miles on the vechile. Dealership check alignment, stated that all is within spec, car continues to vibrate (60, and 80mph), I don't know what to do, can anyone please assit?
Thank You.
Before they did that they did same repairs they did to yours.
