Door panel removal
I apologize if this topic appears elseware. I'd like to remove the top half of my driver's side door panel if that's possible to take a look at the locking mech. since it's started to only operate intermitenly. I'm thinking loose wire or corrosion. I only see one screw on the left edge and removing that does hardly anything. Anyone done this and what's the trick? Thanks.
Once all that's done, you can begin (carefully) pulling the panel away from the door. The whole thing comes off as one piece. There is no such thing as removing the top half. Then you get to unplug the electric connector & set the panel aside.
If your LS is an early one, you'll get good at this if you keep it long enough. If the window regulator doesn't pack it in, the inside handle will.
Enjoy.
I found that you can open the door when the latch is broken by pulling on the lock with one hand and the latch with the other simultaneously. You can actually get away with not replacing the latch until the lock breaks!
..M
Once this is done, flush the spark plug wells clean with solvent and rag then blow them dry with an air hose. Reassemble and now if you find a miss, it's likely a coil or COP. If the gaskets are not replaced first, you will go through many coils never fixing the problem only, disturbing the spark path temporarily until the energy field finds the pool of oil again.
5 years late but worth the wait for those who need this information.
Amazon.com has them for about $50 each without the motor as I wanted to continue using the original ones to maintain the same sound and speed so the global window feature performs equally as it had.
Now for a clock spring, advance trac/abs module and upper timing chain tensioners, yuk.
A common cause of the airbag warning light is the harness under the driver's seat. The 5 beeps could be due to the airbag warning light being burned out. You didn't swap out the gauge cluster, did you? If you did that will cause beeping if the cluster isn't re-programmed by a dealer.
