Chevy Tracker Transmission Problems
in Geo
My 90 Tracker has an auto tranny. I goes into low gears fine and pulls well, but when driving it on the highway it trys to shift into 3rd gear and there is nothing. Almost like shifting to neutral. Any suggestions appreciated. The previous owner drove it through high water and I believe that some of the water go in the tranny. Could that have burned up the fiber clutches?
I am looking at buying my first Tracker, a 2001 5 speed std with 138,000 klm on it. It runs well but I find it very hard to shift into first. Are they normally hard to get into gear?
http://www.atra.com/consumers/bulletins/cb-111.pdf
chris
Melina
Is this normal for this vehicle, or do I have a problem with it.
If so what may be causing it??
I have a 99 chevy tracker soft top. Automatic trans. 96000 miles.
Problem #1: When I hit anywhere from 35 to 45 mph (exactly) it does a weird jolt/ jarring thing, like it can't quite shift gears or something. (Obviously I am not a car expert!)
As soon as I go above 45, it's fine. Below 35, it's fine. Just at 35-45mph. Any ideas?
Problem# 2: when idle (like at a stoplight, sitting in traffic) it shakes a bit every once in a while. Sometimes it trembles all over, sometimes just a little kick, then nothing, then a few seconds later, a kick, then nothing. Is this a timing issue? WHen in neutral it's fine. In park it is also fine. What can I do to fix?
Thank you!!
I don't know a lot about the transmissions, but when my Tracker broke down and I had to tow it to a garage (towed it myself), I found out that an Automatic transmission can't be towed! (Not reccommended by Chevy.) They suggest towing with the rear wheels on a dolly, so the transmission isn't turning.
The reason is that the transmission is only lubricated when the engine is running. As I was told, the automatic transmission can be burned-up, towing for a long distance, as the fluid is not being circulated in it.
Now, I don't know about the manual transmissions, they are probably OK to tow, but I would check with an authorized mechanic that knows more about it.
(It's mentioned in my owner's manual.)
Hope this helps and saves you a new transmission again.
Snichol
thanks for your help.
MY QUESTION IS:
(1) IS IT NORMAL FOR THE INPUT SHAFT TO GO BAD?AND WHAT CAUSES IT.
(2) WHY DOSNT IT DO IT IN ALL GEARS?
(3) DO YOU HAVE TO REPLACE THE WHOLE TRANSMISSION TO FIX IT?
I'm wondering if this car is a keeper though. Overall, how do you like yours? Any weaknesses to warn me about?
I'd appreciate any help I can get.
Bruce
Yesterday my brother's 98 4wd 3 spd a/t chevy tracker, 2d soft top refuse to drive in D, 2, L it only drives Rear even in position N. There is some leak from tranny but we filled it with fluid and there is no difference
What ther can there be a problem?
Now we are trying to find it by ourselves.
Thank you in advance
. I have a 200 Chevy /Suzuki Tracker, 2.0, 4 cyl. Auto, 4 wheel drive. The transmission sometimes pops out of OD./Drive or appears to.. The tach goes way up like stepping in on a clutch...You back off and feather the gas pedal and all is good .. Hasn't done it lately but now the weather is in the 30s.. seemed to do it below 25 +or.-Seemed to have started the problem after the 4 studded snows were put on,,,. Trans fluid OK. a little dirty but not burnt.
48000 miles on the Tracker.. Bought used w/420000...
Low idle s around 6/700 rpm,IMO too low ,but that is normal from what Ive heard and can not be adjusted because of eletronic ignition...
Check engine light is on and will be going to shop soon..Road around about a hr today no issues. BUT Cars do not fix themselfs lol
I would like to start by saying thank you for the wealth of information provided on this forum, I can tell you know what you're talking about. A lot of this is far too technical for me, so I 'm hoping you could help clarify some things and pump a little life into this thread.
RE: 1994 Geo Tracker LSI (not sure of engine type) automatic transmission, 91K mi, AUTO HUB
My problem is similar to many others out there: My tracker has problems shifting from 2nd to 3rd gear in cold weather. Once it warms up it's fine, but before then it feels like its popping out of gear and into neutral when shifting into 3rd. At that point I take my foot off the gas and let it back down to about 3k rpms where it will go into gear. If it doesn't go into 3rd I put it into "2" and let it warm up a little longer. Once it is ready and does go into 3rd I have no problems with it until the next time I run it cold.
Based on what I've read on this board I suspect it has low pump pressure, and a lot of sludge/grime caught up in the governor. The seals are obviously old and probably also have something to do with it. Also the MOD valve and vacuum modulator might need to be changed.
Before I take it in for the full inspection/tuneup/overhaul I want to make sure I tell them what to look for.
On another forum a guy said he poured in 1 ounce of clean brake fluid into the transmission and that after a day the problem was more or less fixed as that caused the seals in the tranny to become more pliable.
From what I can tell the car has been regularly maintained and serviced, with a tranny flush being performed 2 months ago (according to the guy who sold it to me).
Any help/suggestions you may have would be much appreciated. Thank you for your time.
Sincerely,
Ryan
Noise gear box. What will interchange? Any information out there? :mad:
Daniel
