Jeep Grand Cherokee Need Help
Hi folks! I need help on this: I own a jeep grand cherokee laredo 6 cyl. yr. 2000. After an stop to refuel the a/c fan only work in high speed. The compressor is fine, Thanks in advance, Joe :confuse:
located on pass side by feet well held in by two screws bout 2 to 3 inches long 2 inches wide has 3 or 4 wires pluged in to it remove screws unplug wires replace and you should be ok to go
have to get part from jeep (blower moter resister)
Christine
My 98 GC (99K, good condition) has the following problem:
I'm driving at normal speed.
The air bag and seat belt lights go on and stay on.
Then all the dash guages stop working, Even the odometer goes out.
I turn on the heater fan and all the warning lights on the dash go on and stay on.
The red security light on the top of the dash goes on and stays on.
The power windows stop working.
The radio has lots of interferance on the AM dial that it didn't have before.
All the while, the jeep runs fine, even the dash lights work when I turn them on.
I stop, turn off the jeep, take out the key.
I put the key back in and start it up.
Everything seems to be workng right now. Even the radio has no interferance.
This has happened 3 times this year.
Any ideas!!!
SUVs and Smart Shopper
if more than two years old change battery try that cheaper than throughiny money at your prob looking for the cause if dont fix not that expensive
I would appreciate any information I could get. Thanks!
topat46
Topat46
wasent to hard just remove 4 bolts holding to floor take seat with track out tip over remove old track replace in reverse order
prob have to get track from same year and mod from junk yard
if you did is noise coming from front or rear?
if from front pad is not seated right
from rear could be emergancy brake shoes hold down spring broken or fallen off shoes.
thanx,
H20s8
have you run low on gas as they count on the pump to be in gas to help it run cooler
i would also check the fuel regulator and return line to the tank, as if that is plugged or not working ok could put to much pressure in fuel system and cause the pump to work harder that designed to
