A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
The '03 4Runner is significantly lower than the 3rd gen...therefore, it's center of gravity is much improved. I would expect it to get 3 stars.
I read (Car & Driver) that the GX470 has a very low center of gravity. GX engineer said that it was nearly impossible to roll the GX. I assume the same is true for the '03 4Runner.
Consumer Reports thinks a rollover test should be a moving test. That is what they do, and they get sued every time a SUV does not pass their test. I know Consumer Reports has asked the government to come up with a moving rollover test, but no standards have been done.
It is also true the 3rd generation passed the Consumer Report test. It was came back with the fastest speed for the test, which included 4 other SUV's. (5 if you include the Montero which flunked the test.) Consumer Reports credits the VSC (vehicle skid control) in getting the good numbers.
"I have heard that some dealers might be offering incentives (0% APR or 1500 off invoice!?!?)."
I think $1500 off INVOICE is unlikely, but I might be wrong. $1500 off MSRP is possible, because that's about $2000 over invoice.
As far as the spoiler is concerned, I think it's probably cosmetic.
Hope I have been of some help.
Here's where you can read all about NHTSA Rollover Research
I wonder how come 4runner is being sold at 500-1000 over invoice in spite of more improvements in 2003. I mean, I would have expected it to be selling to closer to MSRP for a brand new redesign. I guess, people are not jumping for these as much as Toyota would have liked them to. People get put off by cladding of SR5s and prices of the Limited. Just a thought.
By the way, can someone comment on these:
1. Rear spoiler - useful or purely for cosmetics?
2. CD changer - is it smooth and quick or takes forever between changing CDs?
3. Invoice and MSRP for the DVD entertainment system. I know that Toyota is not manufacturing these yet, but I would have expected the price to come out by now for this option. Dealer says he can install it post-production for about 1800$.
Thanks again,
Samir
of 1)timing belt vs timing chain 2)aluminum vs non aluminum engines on the new 03 4 runners?
main site
http://www.motortrend.com
article
http://www.motortrend.com/oftheyear/suv/112_0212_suv/index.html
Last October a Toyota dealer on their website posted:
"The Toyota 4Runners engine uses a cast iron block for durability, while the Pathfinders engine use an aluminum block. Aluminum engine blocks are much more prone to warp and crack at high temperatures than cast iron."
I am sure they are not posting that now. Here are my pros & cons:
Aluminum block: Pro: Lighter, better transfer of heat. Con: Read above paragraph found on a Toyota site last year; i.e. less durable. Also more expensive.
Cast Iron Block: Pro: Strong, durable, good under load, cheap. Cons: Heavy, transfers heat less than a aluminum engine.
Timing belt: Pro: Quiet, flexible, easier to replace. Con: Breaks before a chain, not as durable.
Timing chain: Pro: Strong, durable, will last longer. Con: Nosier, more expensive to replace.
I think a better question is "Is the engine a interference or non-interference engine?". Meaning when the timing belt or chain breaks do the valves get bent or not. I know the old 3.4 V6 is a non-interference engine, which is good. If I were looking at the difference between the engines, I would think this would be a big difference. Sorry, I don't know if either engine is a non-interference or not, perhaps someone can let us know.
Anyway, that is my two cents worth.
I looked at getting extra keys made for the new 4Runners. What a pain!
They have it setup so the dealers can ream you on this. The dealers don't seem to have the story straight on keys yet either.
The keys have a chip in them for added security. Supposedly you can only have 4 total keys programmed for the car. If you try to program another one, you need to have the controller EEPROM totally re-flashed (or buy a brand-new controller). To do this they have to take out the controller and send it somewhere. I heard that this annoyed Lexus owners so much that they started doing it free for them.
The dealer told me that you have to bring in ALL the keys when they program the new one. A new key cost $40 and the charge you 1 hour of labor at $80 for about $120 for a key.
Then I called a local locksmith and he agreed that was rediculous. He looked into it and found out that:
1. You don't need ALL the keys to program a new one. You only need 1.
2. He will sell the keys for $30
3. He'll help you program the key. The sequence involves getting in the car with the windows shut, turning the key in the ignition, pumping the brakes etc., etc. This seemed like it should be in the owner's manual.
My wife lost a key and transmitter on an earlier car and I cringe to think about going through all this if she loses 4Runner keys. Keep in mind that the transmitter is a another cost to replace that I haven't looked into either.
Anyway, the question is do you really only get 4 total keys before having to go through the re-flashing?
Does anybody have any other information on this?
Thanks in advance,
Eric
Advice?
Hope this helps.
Ken
It is not a greatest engineering practice, you need to be sure to change the timing belt or chain when it is time to change. If you risk going further, you may have expensive repairs.
One concern I have about a timing chain with a interference engine is it is usually a long time before you have to change the timing chain. Usually 120,000 to 150,000 miles. Since it cost more to change a timing chain, I wonder if people who own a vehicle with 150,000 miles will be willing to spend the money to get it changed. Of course, if you buy a new vehicle, you probably won't keep it that long, it will be someone else's problem. : )
P.S This is the smoothest drive train I've ever owned and can't wait till its broken it a bit.
cheers steve d
We test drove several Sports without side airbags that had a different design for the visors. There was a plastic panel that extended from the end of the visor to help it cover the side window but this one did not have the lighted mirror.
The owner's manual for our truck shows pictures of both styles with instructions on how to use them. From what I can see they both get the job done.
Apparently new vehicles are transported with the tires at elevated pressures so I ask our sales person to please have them checked before we drove off on a 300 mile trip home with the new truck. As we began driving, I thought the ride was a bit harsh and the steering overly loose but it took me 30 miles to decide to stop and check. All 4 tires were at 45 psi. We were in rain and Washington DC Beltway traffic those 1st 30 miles so I am fortunate not to have had an emergency stopping situation.
I hope this may help someone else someday.
Any experts here on possible solutions before I get the dealer back on the phone (300 miles away) ? Maybe I can get an SR5 hood without the "scoop" for my Sport.
Now, if the timing belt or chain breaks, the valves spin to a stop, but the piston keep moving. Some valves will stop at the closed position while some will stop in the open position. The piston that keep moving will hit the open valves, ouch.
A co-worker had a Honda CRX and broke his timing belt. It had a interference engine, as most Honda's do, and the valves got bent. It was cheaper for him to buy a re-built engine than to get the valves re-built.
A non-interference means the valves and pistons won't interfere with each other and if the timing belt or chain breaks, no ouch. Having said all this, I have no idea if the 4.0 V6 or V8 4.7 is a interference or non-interference engine. How did I do in my explanation? : )
After seeing this, I called the dealer's finance person and so far have had no returned call (my guess is that the dealer has my money so why worry about service???).
Anyway, here are a few questions:
1. Did I get taken and purchase an "after market" warranty from a company that nobody's ever heard of before and may not be around if/when I have a claim?
2. Any suggestions on how to cancel the original contract and buy a genuine Toyota warranty?
Hoping to stay calm,
swalis
I would go to the manager of the dealership and tell him or her your displeasure of not getting a Toyota warranty. I would think that would be a 50-50 shot of correcting your problem. If not I would then contact Toyota US and tell them your problem. I am sure they would not be happy at dealers selling a non-Toyota warranty. That might get things rolling.
Having said all that, dealers can be a pain in the butt and are slow to change their practices.
I imagine you know how much you can put down, and you can find out about how much your trade in is worth (if you have one) through Edmunds or any other car pricing site.
At that point, you need to shop for the best total purchase price on the car. You also need to shop for the best APR loan. You can test different loan terms to see what kind of monthly payments you come out with. I believe Edmunds and other sites also have a financing calculator on their site. Start there, start putting in some numbers that approximate the cost of the car you're buying, and the other numbers, and see what you come up with. Everyone's situation is different, so getting monthly payments from other owners probably won't be indicative of your situation.
better for towing (lots of torque and transmission cooler)
Better 0-60 (7.4 s versus 8.8 s approximately from the web)
5 speed tranny
proven engine (been around for 3 years or so)
No 2WD mode
v6
Better gas mileage
Unproven track record (but might be just fine)
Higher tech. (VVTi, Aluminum block, ULEV)
Costs $780 less than v8 version
2WD mode
I was curious if anybody else is having this problem.The chirping in the front end (the dealer thinks it the shocks) happens when I hit a speed bump going 5 or more miles per hour.They happen to have a speed bump in front of their service center and we had 5 or 6 people listen to it with nobody knowing what to do.Then they went and got a new 03 4Runner off the lot and went over the same speed bump with the same chirping results.So far there isn't anything from Toyota to fix this problem.
Any help sure would be appreciated
Thank You-Rusty
>So the V6 is ULEV? Is the V8 LEV?
That's what the literature shows that I have seen.
-Eric
Titanium with either stone or taupe cloth
Galactic Gray with either stone or taupe cloth
Black with either stone or taupe cloth
Dorado Gold with taupe cloth
Stratosphere Mica with either stone or taupe cloth
Now, as to finding a dealership to sell a Toyota warranty, you might try e-mailing different dealerships. Any dealer that offers Toyota plans can sell it to you. If you look around, perhaps even in this topic, you will find dealers who can assist you. There are also web sites run be dealers that offer them as well.
Listen up folks - the truck is crap. I traded a 2002 Trailblazer which was much better in terms of quality and dealer service.
· Color-Keyed Front and rear bumpers
· Color-keyed cladding
· Color-keyed REAR License plate garnish
· Fog Lamps
I was told they should start showing up at dealers later this month at the earliest.
The colors stated earlier above are the only exterior color models it's available in for the SR5.
