Could a Lexus LS 400 or LS 430 go over a Million Miles?
stephenabelson
Member Posts: 23
in Lexus
Any thoughts on whether or not a Lexus LS 400 or LS 430 could drive over one million miles on the original engine with proper maintence maintained throughout the cars life, garaged and treated well?
Has anyone seen a Lexus with one million miles? Everyone always talks about how reliable and long living the Japan cars are, like Lexus, Toyota & Honda but I personally have not seen any with a million miles. I have seen a Mercedes Benz with over a million miles on the original engine, also a VW and the guy with the record for having the most miles on a car is a guy driving a Volvo from the 1960's.
Any thoughts?
Any thoughts?
I have a LS 430 with 56,000 miles on it, and its in the shop right now with a keyless entry problem that Lexus can't fix.This is the second dealer that I have taken it to. The first one in Rochester N.Y. told me that they didn't want to fix it. So be careful buying a used LS 430.
Mike
My dad had a LS 400, that he drove 503,000 miles. The motor and transmission were original and were never taken apart other than routine oil and filter changes. The seats were worn out and the leather steering wheel was beat, but ran fine. He traded it in on a LS 430 with 30,000 miles, It now has 56,000 miles and it is in the shop right now with a keyless entry problem that Lexus can't fix, and most of the time there is a warning light coming on for something.
Mike
I'm curious about the designation "Sport Suspension" which appears behind the front wheelwell on a 2002 LS 430 I'm interested in. The car does seem to handle very well considering the criticisms that the suspension is too soft in the literature, also the ride is pleasant, but certainly not "floaty." I find no reference in the literature to a "Sport Suspension" option for the car, and am wondering if anyone can sort this out for me, thanks,
Shoman1
Answer to the million miles: Maybe with a lot of luck and good up-keep. Think of how many times all the bearings are going to wear as the crankshaft, camshafts, pulleys, etc. spin around...millions of times as each mile your car must make 2000-3000 maybe more rotations per mile depending on how long you take to drive a mile.
I have 3 lexus LS400s, each have 215-260 k miles. I've done timing belts (a must around each 100,000 miles) and with each I've pulled the bearings out for idler pulley, tension pulley, etc. Some were trashed making noise 1st 100,000. All needed to be done for sure at 200,000. Also, you will have wear in the trans with the clutch packs..paper type friction material..can't last forever..made to wear so eventually have to replace..
I've had my 94 go up to 212,000 and the trans started slipping badly. Left my daughter stuck out on I-10 about 70 miles from home.. Towed back, pulled and rebuilt for about $1500. Thats not bad for over 200,000 miles. My 95 has 255,000 and trans just starting to act up.
It's always a good idea to take to a reputable shop and have them replace the trans filter w and the usual 4-5 quarts of trans fluid. (i don't believe in the flush part) and I'm not worried with having it rebuilt after 200,000. Also, with each one, the power steering pump and hoses wear and I've bought seal kits to fix and hoses. Not super cheap, but nothing crazy or unexpected.
You have to change out the coolant and use Toyota Red if you like a hassle free car. I think in my opinion every 4-5 years is a good idea for my climate..high heat. Change the oil with your favorite synthtic on a regular basis....do not let it go for 10,000 -15,000 miles and think it's o.k. it's not.. one time out of 20 changes like that and you are asking for trouble. Also, have the brake fluid flushed every two-three years.. I know most people don't, but bf always draws in moisture/H2O no matter what.. good idea. My power steering rack on each of them has worn and leaked..anywhere from 150k to 200 k...And while your at it..check and replace any backup bulbs, brake, turn lights, license plate lights..
I doubt one could go past 500,000 without some type of work for the trans. power steering pump, water pump, alternator, or belts, and others. Also, the valve guides will wear and the faces of the valves will wear, seats will wear and eventually it will lose some compression. You can't ask a car to go that far without some wear happening...just not going to happen.
I have a '68 corvette and it only had 64k last time I looked, but sitting around for 45 years has taken it's toll on more things than I thought possible..I never complain that I only got 252,000 on a Lexus alternator, or power steering pump as the heads on my Vette are trashed at 50-60k... Lexus LS400/1UZ is by far superior to just about anything out there
I have a Toyota tacoma with 254k...same type issues.. seals will eventually wear/weap and leak..
http://thegarage.jalopnik.com/im-driving-a-lexus-with-900-000-miles-across-the-countr-1684015600/1686272604
I'm not sure you'd even want to drive a car that's gone much over 250,000. Aside from mechanical maintenance, there are structural issues to consider. Metal does fatigue, and that can be dangerous.
