Could a Honda Or Acura go one million miles?
in Honda
Any thoughts on whether or not a Honda and or Acura could drive over one million miles on the original engine with proper maintence maintained throughout the cars life, garaged and treated well?
Has anyone seen a Lexus with one million miles? Everyone always talks about how reliable and long living the Japan cars are, like Lexus, Toyota & Honda but I personally have not seen any with a million miles. I have seen a Mercedes Benz with over a million miles on the original engine, also a VW and the guy with the record for having the most miles on a car is a guy driving a Volvo from the 1960's.
I serviced each car properly and fixed things promptly when needed. I think in every case I could have made a million if I wanted to keep on going.
1971 Oldsmobile Delta 88 (455 2v carb) 460K
1984 Toyota pickup (4 cyl 5 speed manual) 480K
1992 Toyota Tercell (4cyl 4 speed manual) 410K
In my case nothing broke, just normal wear items. At around 200K the Olds started missing from a burnt valve. I replaced the one valve without giving it a valve job and drove it for 260K farther without incident. That was the only incident that caused me to go into an engine. All the cars I mentioned never required any engine or drive train work other than normal service. All were running just fine and used little or no oil when I sold them. I was just getting tired of them.
Keep the oil changed, stay up with the normal wear items like belts and hoses, tune ups, plus service the other running gear on a regular basis and most cars will drive a long long time.
What I meant by fixing things immediately was things like brakes etc. fix them before they do break causing bigger problems.
Just staying on top of the 'service' items can get spendy alright but taking short cuts or putting off those things can cause things to escalate into a nightmare.
I never 'babied' a car either however by the same token I was always mindful of their limitations and tried not to ask more out of them that was reasonable to expect.
I do think cars like Hondas just have a way of making you feel good about having one. I can understand a big car or truck with huge low horse power engines that are never stressed should last longer.
Something about a Honda gives you a better feeling than most american cars of the same size. I think its reasonable to expect more from the Honda.
