Ford Explorer Power Windows
on occasion my rear pwr windows won't open, then the next day they seem to work fine, it can happen to either side?
Where can I find the items to check if they are in proper working condition?
If anyone has a suggestion to remedy this problem please let me know.
They is a fairly large bundle of wire at the hinge. I had to pick through them with a crochet hook.
I then pulled off the interior panel on the inside wall ( by parking brake petal) to find the other end of the wire. I need to splice a short piece to both ends.
The rubber boot ( at hinge) is pretty touch to get back on - need to be patient and hope for the best .
Good Luck
Ron
http://www.explorerforum.com/forums//showthread.php?t=255318
I was actuality able to squeeze the black rubber boot to get the windows to work.
Here is a web link with pictures of broken wires in the driver's door hinge.
These are not my pictures but it was the exact problem!
Ron
Ron
The window went down and will not go up.
Door locks on passenger side work.
When window button is pressed to open, light on button goes out.
All other windows and power work.
Recently, I have had to have engine on to open/close window
I just want the window up,I can live with not opening window.
Any suggestions? Thank you
We are also having problems with the driver's side lock - it will no longer respond to the remote. I have to reach in from the back seat and open the door.
What is going on? Are these 2 problems connected? Anyone else having these same two issues? Any ideas on what to try next?
Yeap, Definitely a broken wire within the rubber boot @ the driver side door. My 2003 Explorer had a brown wire w/ a blue stripe that was broken.
