Chevy Express/GMC Savana Tire Questions
I would like to confirm if the correct pressure tires for the Chevrolet Express Van is really 80 pounds?
The tires in my 2500 Van is:Pirelli Scorpion ATR, 245/75 R16.
If I put less them the recomended the tire pressure monitor start to blink!
But with high pressure the van becames too roughf, almost impossible to drve on the city.
Any sugestions?
Any sugestions?
The tire pressure on the tires is the Max pressure needed to carry the Max Load rated for the tire.
It is the vehicle manufacturer that selects the correct tire pressure to carry the load expected on the van.
Are you running the van empty i.e. no load?
Are you sure the tire size and type is correct for the van?
I have Bridgestone V-Steel 265s on it now and they are OK, but I want a different tire for replacement. A lot of people with camper vans don't like the Michelins because their soft ride lessens their stability. Anyone tried out the Grabbers HTSs?
My 2007 190 RoadTrek Chevy 3500 Express is to low to the ground Dragging plastic.
Factory size tires to low! Came w/Brifgestone and has stability problem behind larger trucks.
Thinking Michelins LTX M/S-2 and go two sizes larger than what came on it.
And taller is not really the right direction. That aggravates the problem.
QUESTION.....do I need to go to the dealer to have this done or is there a manual method that does not require a special reset tool?
