Chevy Tahoe Headlights
I have a 2003 Tahoe and I am unable to turn off the headlights at night when the vehicle is parked. I have had people tell me to hit the dome over-ride button three times in a row and it will shut them off, however it does not. Someone also told me to set the emergency brake. I have done that as well and it still does not turn them off at night. I called the local dealer and they do not have any other information. Does anyone have any other suggestions?
SUVs and Smart Shopper
Do they stay on permanent as in never turn off and drain the battery?
I have a 2003 as well, the headlights stay on about a minute after removing the key from the ignition and opening the door. I've never really timed it. If you want ot over-ride and shut them off turn the headlight switch CCW to "off" and then release it. It will go back to the "Auto" position. That should turn them off until you re-start the Tahoe or turn the switch to the On position.
--Jay
____________________________________________________________________
Rotate the headlight switch as far left as it will go....that will turn off the headlights.
I'd have to get the schematics out to see what all else might be in the circuit in addition to the BCM (Body Control Module) and relays, but at this point I'd be focusing on checking out the headlight relays...and hoping that they are the problem.
Do you have an electrical digitial volt/ohm meter, and do you know how to check whether a relay is good or not?
Is this wiring all OEM, or has anybody messed with it putting on alarm system or anything else to the wiring?
I tried to release the e brake numerous times. Over And the auto headlights won’t come back on. I still there a way to reset this ? Thanks.
