Best Tires suggestions
bxnybxny Member Posts: 1
I have a 2001 Park Aveune in need of tires. Do you have any suggestions for a quiet ride and good traction in wet weather?
  • russellburkerussellburke Member Posts: 4
    The Michelin harmony have been on my Buick P/A's for some time. No problems and would buy again.
  • PAmanPAman Member Posts: 207
    Ditto. Just make sure the tire says "Michelin" on the side, and as long as it is the proper size, mounted and inflated to specs, you'll be very happy.
  • leonardgleonardg Member Posts: 2
    If you haven't purchased yet, I recommend not going to NTB. They try to replace close to what you have and ended with vibrations no matter how many times adjusted and different stores, finally went to the top and they ordered special tires that were like originals. I should have gone to Conrads - that is where NTB got them from. I also should have asked my S-I-L that is an engineer at Goodyear.
  • ultramannultramann Member Posts: 1
    Hi !
    I have a 2005 Buick Park Ave Ultra that needs 4 good tires that will not cause vibrations at highway speeds.Mine has a terrible sweet spot at 68mph that makes it feel like a jackhammer under the seat of my pants! A local tire shop recommened Cooper CS4 tires. Has anyone ever used them before? He does not use the Hunter wheel balence system. (roadforce?)
    I also read that Michelins are recommened by some on the net .
    Thanks in advance for some info on my decision,
    Thanks, Kevin
    Buddykev@yahoo.com
    If you want smoothness you'll want to buy Michelins at a place that does RoadForce balancing on a Hunter 9700 balancer.
    Also get the alignment set right on the specifications front and rear--do not accept "close" or "within tolerances" as good enough.
  • cruiser59cruiser59 Member Posts: 3
    Hi there. I just acquired a beautiful 1999 PA with 70,000 miles and running Michelin Agility Touring tires, they have about 30,000 miles on the set. I just drove from California to Florida (3160 miles) with my brother. The car was flawless, the tires were as expected (Michelin owner on other cars) and the average mpg was above anticipated mileage.
    My humble experience is that with some solid research, good tires are a must. Road force balancing is a must, proper inflation is a must and the ride will pretty much take care of itself, assuming the remaining drive components are within specs.
    Thanks for listening. :)
  • shipwreck83shipwreck83 Member Posts: 1
    I have them on the front of my 99, they're affordable and I like the feel of them, in fact, I'm going to get them put on the rear later today.
    @stever best tires for a 2006 Sienna xle, fwd model . My recommendation is Continental True contact
    225 / 60 R 17 99h or 99t ................... Thoughts sir
    Where have I seen this before? Oh yeah, my profile wall. :)
    I really liked the last two sets of Nokians WRG2s I had (one set on an Outback, the other set on the Quest). Hard to find and a bit pricy though. Got Primacy MXVs on the current van and they've been better than other Michelins I've had. Haven't had Continentals for decades so can't really say. Lots of good choices out there.
    stever thanks will check out your recommendations and pass them on.
  • kyfdxkyfdx Moderator Posts: 276,083
    If you drive in winter weather, the Nokians are hard to beat. I had a previous version on a Honda CR-V.
    But, as an example, my closest retailer is 45 minutes away (and, I live in a metropolitan area). And, they don't come in the size for my wife's vehicle.
    edited April 2016
    @Kyfdx you are correct just checked the reviews on the Nokians. Seem like a very good winter tire but here in the Tri-state area not needed.
    Tire Rack seems to like for this climate either a Michelin, Conti , General, Goodyear all season tire.
    I"m still all in for recommending the Continentals true contact tires for the Sienna. Tire rack really likes them also. They had a video that put Conti's up against 4 other tires in this class. The Michelin premier a/s tire that Tire rack recommend did not get rave reviews for that price.
    I liked the Nokians on my minivan because they did well in the rain. And they weren't noisy in the dry conditions.
    Nothing much helped it going uphill in the snow. :)
