Volvo XC70 Transmission Questions
i have a 2001 xc70 105,000 mi. the tranny is clunking when it gets warmed up, stopping and starting. it doesn't do it at highway speeds. when its cold it doesn't do it at all. no messages as in check engine lights. any suggestions?
john
john
This was not the news I had hoped for. Because I had paid for an hour of diagnosis time, he went ahead and gave the car a thorough once-over and came up with $3,500 worth of needed repairs (none of which related to the vibration issue I even brought the car in for). One of the items on his check list was a recommendation that I flush the transmission fluid (removing the old fluid under force and replacing with new). I talked to a few people and all seemed to agree that flushing the transmission fluid can be a dicey proposition. Apparently, it's common for a flush to sometimes dislodge crud from within the transmission that creates more harm than simply leaving the fluid alone in the first place. I chose a compromise approach. Instead of a full blown flush, I would simply drain what I could, add fluid, drive the car for six months and then replace the fluid again. My thought was that this would replace most of the trans fluid without the potential harm of flushing all of the fluid at once. Yesterday I drained about a gallon of trans fluid, got in my chevy truck, drove to the dealer, purchased four liters of Volvo authorized trans fluid, added enough fluid to replace what I had drained, and then test drove the XC70. Much to my surprise, I had lost third gear. Reverse, 1, 2, 4, and 5 are just fine. Three no longer works. I've searched the internet a bit and apparently this is fairly common. I'm sick to my stomach. Short of $3,000+ for full-blown transmission work, does anyone have a solution?
This was not the news I had hoped for. Because I had paid for an hour of diagnosis time, he went ahead and gave the car a thorough once-over and came up with $3,500 worth of needed repairs (none of which related to the vibration issue I even brought the car in for). One of the items on his check list was a recommendation that I flush the transmission fluid (removing the old fluid under force and replacing with new). I talked to a few people and all seemed to agree that flushing the transmission fluid can be a dicey proposition. Apparently, it's common for a flush to sometimes dislodge crud from within the transmission that creates more harm than simply leaving the fluid alone in the first place. I chose a compromise approach. Instead of a full blown flush, I would simply drain what I could, add fluid, drive the car for six months and then replace the fluid again. My thought was that this would replace most of the trans fluid without the potential harm of flushing all of the fluid at once. Yesterday I drained about a gallon of trans fluid, got in my chevy truck, drove to the dealer, purchased four liters of Volvo authorized trans fluid, added enough fluid to replace what I had drained, and then test drove the XC70. Much to my surprise, I had lost third gear. Reverse, 1, 2, 4, and 5 are just fine. Three no longer works. I've searched the internet a bit and apparently this is fairly common. I'm sick to my stomach. Short of $3,000+ for full-blown transmission work, does anyone have a solution? I want a do-over. Not just with the transmission fluid but with the whole car. It's too fancy, complicated, fussy, and expensive to maintain.
How is the cooling system on your car? Does any of this sound familiar?
Volvo transmissions now cost $4200. for the transmission + labor (about $800-$1000. I was recently having tranny problems and need to have it repalced. I thought that having it rebuilt and saving $2200 was the way to go...but I was mistaken. Nobody really knows how to rebuild a Volvo transmission properly and if they do, you will still likely have other issues upon getting it back. I just spent $2300. and still have problems and need a Volvo transmission replacement.
Any advise would be a help! Thanks! :confuse:
2004 xc70 - car had a tendency to shift gears somewhat harshly, not a smooth transition. purchased used with 20k miles, sold a year later only because I got more than what I paid. mpg was about 24
2002 s60 - 28 mpg was great. At about 70k miles the trans would shift more harshly into first. What I do is manually downshift coming to a stop, saving the brakes a bit (it does work). Apparently the car does not like that and developed that harsh shifting after a while. I don't do that anymore with that car. Then starting at about 95k miles going into gear after backing out of my driveway, it takes a couple seconds to engage into forward gear. Usually you hit the gas as soon as you shift from Reverse to D but doing that jerks the car at engagement. Since then I have been waiting those seconds with foot on the brake. With care I think the car will last a few more years. Now about 25mpg. OEM tires were replaced with Goodyear tires rated at 80k miles and after 40k the fronts are shot. I discovered after some research after the fact that the same tires can perform differently on different cars.
2006 xc70 - bought new with extended warranty, given the experience with the 60. When manually shifting this trans is exhibiting the harsh shifting as the previous 70 but not quite as harsh. I stopped the manual shifting since I startred noticing it at around 45k miles, now has 60k miles. At purchase, mileage was under 20mpg and slowly crept to 21, 22, and at 40k miles was getting 23.6mpg overall. The Pirelli Scorpiion oem tires were replaced at 60k just this past week and performed very well. I replaced with Michelin Harmony with the same size. A weekend trip of 800 miles resulted in 24.6mpg, a very notable and happy improvement! Purchased at Belle Tire $517 out the door with lifetime balancing, rotation, flat fix, inflation, etc. And I also asked if there were any senior discounts available and I got another $20 off! You don't have to be a senior.....don't ask, don't get.
Long post but I hope this will provide some insight to someone. Other than the trans, I've found these cars to be pretty good and the wife loves her 70. I just hope Volvo (Ford) recognizes this.
The car has only 55,000 Miles!
COMPLETE REBUILD of the Transmission. The problem started with a defect in
the valve body and must be replaced to insure no further problems. The total price I had to pay was $2995.00.
On my '03 X-type I replaced the fronts at 65k. The mechanic said that was a lot of miles on original pads. I told him I use the accelerator mostly.
But with these Volvos...I would not recommend it. Also, it seems the tie rods are a very weak element. My '06 XC70 has another tie rod loose (replaced at 55k and now at 65k) according to the mechanic who changes my oil. Fortunately the extended warranty will cover that. And my '02 S60 has tie rod issues, too.
Cheers.
well i have a 2001 xc70 with 92000 mile i purchased it 2 years ago. i have had some minor maintenance repairs (which i have a feeling people think expensive maintenance is a problem and makes cars un reliable) however my main concern is the trans. unlike every thing i have read on this site my trans seems to slip into fourth with a rather HARSH jolt . and it is when i am in a rather slow pace. now i have been told several times that this can all be remedied by a simple software update?????(is this the case ) please hit me up with your thoughts . take care all my volvo friends
Unfortunately this is not the deal. I thought the same thing and my mechanic who I believe is a pro told me that the problem has nothing to do with software updates.
Your problem ("my trans seems to slip into fourth with a rather HARSH jolt . and it is when i am in a rather slow pace.") sounds EXACTLY like what I experienced. I had to have the transmission replaced at a cost of $3000--ouch !! The car now runs like brand new. Oh and by the way my car had only 57,000 miles on it. Sorry for the bad news my friend.
thanx
It's an ocean race edition.I looked every day for 6 month for this car. (I raced sailboats at a hight level) but now I don't know if I can afford to keep it.
Don't let your mum preform any magic on your car>>>
So disappointed...
Oceanxc
i have owned many volvos and this is unheard of a new tranny at 122,000 miles!
good luck.
kcram - Pickups/Wagons Host
Does anyone know anything about Volvo's say about several complaints and problems re their transmission. Thanks.
The form is fast and easy and lets them know people are having issues. If they get enough complaints, they will issue a recall and the company will be forced to start covering their faulty work. Perhaps Volvo will begin to rebuild its good reputation!
What the heck, with all these transmission problems don't the dealers or Volvo realize there is a problem??? jeez. I have purchased my last Volvo as a result of this. There are too many transmission money horror stories in this forum. :mad: ">
well my mechanic at the time told me the only thing that was wrong was i needed the software update....however i never got around to it =( this past aug i was in a accident and the "icis" was totaled ....so now i have a 2005 touareg....came highly recommended by my mechanic...however i miss her very very much ...but the touareg is softening the blow
