GMC Jimmy Heating and Air Conditioning Problems
My jimmy just started blowing cold air at idle and slower speeds, but when I get up to higher speeds (50mph) or more it blows warm or hot air. I also noticed that my 4 wheel drive don't work either, not sure if these problems are related.
Clueless and not a mechanic,
Donnie
Donnie
What do I need to replace/check?
:confuse:
Thanks in advance.
If it is really noisy, doesn't cool, and you are sure the freon is still in there, I am afraid you may have a worn out compressor. HOWEVER, on my '99 Blazer, the same thing happened and testing showed it was down on freon. Charge was added and a leak test performed. No leak, and two months later it is still working great. The ac guy had the right attitude. Instead of "you need a new compressor", he took the logical approach. "This sucker is eight years old. Some of the freon is going to leak out sooner or later. And this particular system doesn't have that much in it to begin with."
I like a mechanic who can think logically.
Now it will make ice cubes!
I have had the normal coolant in the vehicle for a little over a year now and have had no issues at all. I have heard the Dex Cool will eventually eat away at all the hoses and some metal parts in the engine. I have no idea why Dex Cool is still being used and why it has not be recalled.
Then, just in front of the passengers side firewall is a large aluminum cylinder with freon lines going to it. There will be a thing sticking out of the side of it with a connector plugged to it. This is the pressure switch. Disconnect the harness and jumper the contacts with a paper clip or such. This will tell the compressor that there is pressure in the system and keep the compressor clutch engaged. If that compressor starts really rattling or banging, pull the jumper out and find a good A/C shop. It could still be a low freon condition, but more likely a shot compressor.
Great. My '99 has 78K on it.
Does have an odd little rattle coming from somewhere at certain engine speeds, but not a/c related. Maybe cat?
Sat am I finally broke down and took it to the dealership. It will be looked at Monday 4/16. I'll keep you posted.
By the by....I subsequently [ut the same scenario on the buick rendezvous site. More info coming in there.
For some reason the a/c blows cold and then warm, it is constantly switching back and forth. I told the service manager about it today while it was getting a window switch replaced. I asked if if just needed recharged.
He said " No, it wouldnt blow cold at all if it was low on freon. It must be a switch going out. "
What do yall think? If it is a switch, can it be replced by yourself or have to have a shop do it? And what and where is this switch?
If a switch it could have an intermittent short or connection on the compressor or the pressure switch - AC guy can find it .
