Acura Legend Maintenance and Repair
I just purchase a (1 previous owner) 1995 Acura Legend LS Coupe with 114,000 miles. The vehicle runs excellent except when I start the engine, the RPM sometimes dropped way down low after the first cranking that the engine shut down completely. Any advices to resolve this problem is appreciated. P.S. I love my car!!!
would it be to repair.?
Good luck - hope we can help.
maybe someone here can help, I owner of a 93 Acura Legend 4-doors sadan with the 5spd manual shift. I need to replace my transmission. My question can I replace it with a 6spd which comes in the Acura Legend 2-doors sport coupe, with no modification?
Any ideas on what might be the issue?
I drove about 40 miles to home like this, with the back-and-forth shifts between drive and neutral occurring about every 30 sec., the S3 and S4 indicators glowing and the tach needle dancing. On a final hill climb, I had to shift manually to low gear. [edit: no check engine or other dash warning lights.]
This is a great car; I hope it's a simple, not-too-expensive problem like a control module. Any ideas out there? Please? Jack
Driving it for about two(2) miles, it runs fine until it suddenly shift down to second gear then back again to third and so on. Turning it off and re starting gives another two mile of good speed until it shift down again. Draining and changing the solenoids did not help at all. Wiring were check and replacing the trans. controller did not change a thing. I drove this car from NY to FL then to CA and back to NY without any problem at all, in short I a very satisfied owner. I think only a Volvo 240 can match this record. I would love to hear from anyone who got the same problem and advice how they have fix it.
it is not aligning properly on the reverse selection. Hopefully your synchormesh gear on the reverse gear are not worn.
A month or so ago I had my battery disconnected and never got around to recoding the radio.
Today I pulled out the ash tray and to my anger someone had scraped off the code from the bottom of it. I will call the dealership tomorrow but for now am pretty upset that they would do that. What benefit would someone gain by this action? And where do I get the code now?
Also, I started experiencing my car revving up while I'm sitting still. Neutral or park, and sometimes it bounces between 1000 1500, and sometimes all the way up to 2500....??
