Visitor Agreement.
Ok, I've decided to purchase a new '01 4Runner Limited (Glacier Metallic). It has everything, moonroof and everything possible. I've compared it to just about every new SUV (including the available '02s) I found the it feels the best even though it's not the largest or most powerful.
My initial concern was that I would not be able to fit inside measuring at 6'5" in bare feet. I thought it would be impossible with a sunroof. But neither of these were the case when I did the touchy feely at the dealership. I had more than enough room and the front power seats have to be some of the best that I've ever experienced. Some of the best lower back support in any car seat. I could sit there for hours. They are very comfy. The 4runner is fun to drive, more so than the competitors. So I went ahead and purchased at $32.5K. A decent deal I think.
Ok, my questions are as follows :
Is there a TRD supercharger package (dealer installed) available for the '01 4Runner Limited?
This was a $2500.00 option in '99. Is this still available for 4Runner ? I believe it's available for the Tacoma. This would be a nice little aftermarket tweak. Does anyone have any experiences with this configuration in practice ?
Would anyone out there have any experience with adding a brush guard to their SUV's. Is it worth it ? I intend to do some off roading but I do like the way it looks. Would you have the dealer install or go somewhere else ? Do they resist rust and corrosion well ?
Please share any thoughts and experiences that you can with me.
Thank You Very Much
Major Needs:
1) Carrying capacity for family trips
2) Ease of maintenance and economy
3) Future ability to tow small runabout - 19 foot or smaller
Any recommendations - I'm favoring the 4-runner because of Toyota quality but rollover of the truck-based SUV is concern.
Is anyone seeing prices below invoice on 4Rs in ATL?
Experienced the shimmy and the fan roar and both are normal. On the shimmy, what the dealer told another post here about the rack-n-pinion is correct. It gives you better road feel due to less play between the rack teeth and the pinion teeth, unlike the standard steering gear box which can have quite a bit of play and therfore not tranfer each suttle bump or tire hop thru to the steering.
Also, I have found that the factory gas-pressure shocks that come on the 4-Runner seem to not be valved for as firm a ride (translated to better control) than what most expect. When I would go over a slightly bumpy surface (especially around a curve) it would feel like the rear (and the front to some extent) would sort of shimmy in the opposite direction of the turn. Not cool. What I did to correct this was to install the Bilstein high-pressure gas shocks on all four corners and it makes a world of difference. You can purchase these either thru any authorized TRD dealer (not just dealerships) or any local (reputable) parts house will have the same Bilstein unit that TRD uses. The bottom line is better control and no more shimmy.
There is one drawback and that is in the installation if you are going to do it yourself. The fronts require you to have or rent a spring compressor. The rear is a slight trick in contorsionism as you have very little room or access-angle to get the hex-key and wrench that are required to tighten the bolts on the top shaft into the small space at the top of the shock tower. Crawl up under your 4-Runner sometime and you will see what I mean. That is why the factory Tokico shocks have the metal dust boots welded to the shock stem so you have something to hold on to if you replace them with factory units (I am sure the mechanics are happy about that one). But it is worth all the effort involved. It is a shame though to have to change the shocks on a new vehicle but sometimes that's what you have to do to get the ride you want.
On the engine cooling fan roar, you will hear it when cold (even in the dead of winter). If you have ever taken one apart you will understand. ( I went through this twice with my 87 Toy 4WD) It is filled with a heavy viscous fluid. The way a fan clutch is designed it allows the fluid to settle to the lower part of the assembly. So when you first start up the vehicle this fluid had to warm up a tad and begin to circulate. Once that happens the roaring noise will go away, that is until the temperature rises in the engine bay to the point where the fluid inside the clutch heats up and causes the fluid flow to be restricted making the fan clutch lock-up slightly hence turning the fan blades and making the roar once more to draw more air throught he radiator and cool things down.
Phew .. Sorry bout that long-winded reply folks. Just wanted to chip in and share my experiences.
I have read a lot of posts here with a lot of great information. It's good to see there are those who take a genuine interest in thier 4-Runners.
Good day to all.
This is my first post. I have about decided to buy a 4Runner. I just read all the messages on this board for the good information. hew!
Anyway, today while looking at nice 2000 4Runner at a local Toyota dealership and getting the "rock bottom price" of $26988 from the "Director of Used Cars", he made the comment that Toyota is bringing out a V-8 for the 4Runner in 2002 (he said in a few months). He said that in the context of that he has lots of used 4Runners on the lot (thus the "good" price) and expects a flood more from trade-ins when the new 4Runner comes out. I don't know if this is sales talk or not. I find that hard to believe as I am sure that there would be some news leaks somewhere by now and someone on this board would have heard of it - like Cliffy1. But thought I would pass the info along and see if anyone else has heard anything about this.
Future Telling
But this article may help.
Toyota to hold line on SUV
Steve
If anyone has seen one out there recently, please let us know where - we are ready to purchase, even if we have to make a vacation out of it - we have searched only for one day, but it appears any Thunder Cloud's might be difficult to find.
Anyone know of a way to do a national search of dealer stock, or post a national request?
Also, any idea what is fair to offer dealers over invoice price for 4Runners in our neck of the woods?
Thanks again.
Could anyone tell me what Toyota recommends for front/rear tire pressure on a 1999 4 x 4 4-Runner w/tire size P265 70R16? I don't have a manual and the sticker on the car only gives pressures for P225.
Thanks Much,
Yvonne
Last year the 2001 Pathfinder seem to sell for less than the 2000 4Runner. (The 2001 Pathfinder came out in March 2000.) Now the 4Runner is selling for less. This weekends paper had a 4Runner at Alanta Toyota for 23,000, that is 1,000 under invoice. I also noticed that Team Nissan has Pathfinders at a good price and 0.9% financing. Good luck in your search.
Thunder cloud is fairly easy to find here in Northern VA as tclub pointed out. The trick is the oak interior. Most of what is sent here is gray, unless you get the Limited which only comes with oak.
One reason I am shocked at a V8, is that there will now be 3 V8 SUV's and only 1 V6 in the Toyota line up, if you believe the Highlander is a SUV. I am sure the new 4Runner will be a wonderful vechile.
-Rob
RB
I have taken my 4 runner back for the exact same problem and for a creaking in the rear passenger seat. Neither problem was fixed. I took a ride with the mechanic and he claimed the rattle was the fan that kicked in when the truck is stopped. The sound in mine does not go away when the fan is turned off, it just isn't as loud. The interesting thing is that the noise goes way when I put it in park, neutral, or give it gas. This leads me to believe the rattle is due to some vibration from the truck idling at low rpm. I never hd this problem in my 98 4Runner. As for the rear creaking, it went away for a couple of days then reappeared. I need to try a different dealership
Joe
Acura-check Edmunds TMV.
Joe
1)Just to clarify, 4-runners have a 5,000 pound towing capacity???Does that mean that they will mechanically tolerate (eg a 5,000 pound boat) that kind of load over the years. I am on my second transmission on my ranger apparently because of a 2000pound boat that I pull.
2)Any comments regarding owner satisfaction and dissatisfaction from those of you that have owned 4-runners for a while. What do you folks like and more importantly not like about your vehicle.
Any comments would be appreciated, especially from those of you that tow heavy loads frequently year after year.
gdh2
The 5000 pound limit is the absolute limit, and I would not recommend towing at this limit for a long time. I did tow a 4400 pound trailer for about 200 miles one time, and the 4Runner did fairly OK as long as I stayed below 55 mph (you shouldn't go faster towing anyway). It struggled with this weight over hills, though. Generally, Toyota/Lexus SUVs and trucks don't have towing as their forte, and if you plan to tow 5000 pounds regularly, I recommend you invest in another vehicle.
Interesting reading, especially if you are in the market for a mid size SUV.
Based on the rebates, can I buy for 1500 under invoice for instock vehicles? Has anyone bought recently? What kind of deal did you get. I am not sure about lease or buy. I am in the Boston area
The VSC will not engage at all, even when I spin the rear wheel on gravel. The truck is going back, again, to Toyota for warranty work.
Joe
Invoice - $1500 should be readily available at most dealership in this area.
I want to ask if anyone who has a 2000 4Runner SR5 that has a similar problem. And what would be a solution to this problem since Toyota doesn't think it's a defect.
Is 34,900 reasonable for a completely loaded 01 limited 4-runner with convenience package, rear seat heater, gold package????
Please respond if you have any asweres. Thank you ahead of time.
gdh2
