Vehicle rode quite well. But still have issues. Vehicle wants to follow road imperfections a bit more than I'd like, but superior to the way the Malibu handled.
I have some issue with the seat back support. I may have to go to dealer to see if I understand how it is supposed to work. It won't be the first time the manual seems to have error. It seems that both directions may be changing when only one corner of the button is activated.
I had a dead battery. Buick customer service sent someone, much farther than I suspect necessary. He broke part of the battery case. (not careful and very cold plastic) It was difficult starting the next morning as well and because even at home it was slow spinning after the vehicle sat for a few days I had already been suspicious of battery. I took it to local mega-dealer and they determined the battery was failing tests. They put new battery in but I now notice the paperwork says a 30 month battery. That definitely does not seem right for a car only 3 months old. It probably won't last the remainder of the 4 years.
It would be helpful if someone with a loaded CXS can post the rating of their battery, warranty info on it, or even part number.
I'm not happy with gas mileage. I suspect something is awry. Earlier I had posted that I got 28 each way on a 2 tank trip. After that trip and the loud clang some of us have been experiencing, mileage seemed to drop significantly for my local driving, about 3 MPG.
I ran premium the entire time and was past breakin by time I reached the far end. I have not yet tallied all receipts and calculated but did on a couple of individual tanks. Computer was reading about 1MPG high and it has been indicating less than 25MPG every tank. When asked to let it run to attempt charging bad battery, I slowly revved engine a bit and noticed around 1500 RPM a mild shaking like cylinder imbalance as if one is firing weakly.
Anyone else notice such?
Normally I have found automatic temp control to be quite accurate. This one is not even close having to vary the setting by as much as 11 degrees.
I continue to say, "Tires are the most important part of a car. If they don't stop you brakes don't matter."
Someone had asked about dedicated snow tires and after today I recommend them very highly. The CXS and the Eagle RSA is not designed for snow, sleet or icy roads.
This afternoon I started my commute in very light snow. Then I ran into a traffic jam so I made a detour to my detriment. The road was sleet and icy and when I tried to climb a small hill I started skidding in an "S" side to side direction. There was no traction whatsover. I don't know how I did it but I finally made it to the top of the hill.
But what goes up must come down. And this time I slid to a stop at the bottom of the hill. I heard some funny noises so I assume it had to be the ABS and stabilitrac taking control.
The traction control worked just fine because without it I would be unable to move from a stop at the red light up the hill. Driving on the snow was not too bad as the car seemed unusually quiet. That was not the case however driving on the salted and sanded sections that felt like driving on an unpaved graveled road.
Overall, the CXS with the low 19" profile tires is awful in the snow and I would recommend dedicated snow tires or stay off the road completely.
In these parts when conditions get dicey, the DOT requires dedicated snow tires or traction devices, or you can be ticketed. Since chains are discouraged by Buick and many states don't permit studded tires (OR allows them but we pay a hefty price for road damage) we are relegated to snow tires. Not the M+S rated but those with a snowflake emblem on the sidewall. Or, there are spikes-spider. They're pretty pricey might be the option for areas where you don't have snow/ice for extended periods and only need the device for short trips.
I have an appointment for tomorrow.
You're right about these tires being strange. I did a little checking and found the door sticker does not match the tires and the size on vehicle does not match for CXL. It appears someone swapped wheels with CX because they are only 16".
I will know more today after properly airing tires, I think, but maybe not because pressure on door sticker may not be correct for these tires. But it will certainly be closer than they were with over 10# difference front to rear.
In that configuration it also gave the feel of needing a sway bar on rear. Not the kind of float or road isolation I like and with the tires now stiffer on rear that may go away.
During trip return on a very fast stretch of traffic I pushed my CXL to 16MPH faster than the flow. It was surprisingly tight and quiet. Wife missed guessing my speed by 21MPH.
In the past I've always had someone drive the car while we are away but this time we had no such luck. Nonetheless, the car is garaged so it will not be exposed to the elements and the garage temperatures usually does not fall below 32 degrees. I also heard the fuel line freezes when the fuel tank is less than full so I am concerned about that too.
Todays fuels generally contain around 10% alcohol which is the agent in those additives. The alcohol keeps the water in suspension and not pooling on the bottom of the tank where it could freeze.
A bottle of that stuff in tank might give added protection. I'm uncertain that you'd really need it and not sure what GM position is on such additives.
The battery concern seems legitimate. Some had dead batteries after only a few days and supposedly GM fixed that with an update. I think it had something to do with shedding power load. I've never seen any indication of this happening on my car, even with the battery being dead. Once jumped it had everything come on automatically. To make sure maximum charging was taking place I had to manually turn off headlights, etc.
OnStar notes something about not driving for five days and maybe the remote unlock from them not working. I don't know if they shut down the entire system after five days or just part of it. It sounds like you need to start vehicle to re-enable, but uncertain. You may have to contact them?
New car? You are covered under warranty for dead battery. But if the fuel is bad, that may be your problem or fuel vendor.
Tires flat? They may be a little low when you get back if temps continue to descend, but fine for driving to wherever you get air. They definitely should not be flat.
Your post does highlight the importance of choosing options wisely and taking an extended test ride before you buy.
We were pleasantly surprised when the insurance premium on our new 2010 Lacrosse CXL was only $10 per year higher than OLD Pontiac Bonneville due to safety features, including stronger roof pillers that enhance rollover protection (Federal mandate), extra airbags etc..
We just returned from 700 mile road trip and got the $39.95 GM service deal for oil change, tire rotation and 27-point checkup. They check brake wear, battery output and all fluids. No oil use 3000 after last change with 5W- 30.
Gas mileage was only 26 with highway speeds of 80-85 where possible. At 70 it gets 29.7, but speed has predictable impact. Traction great with 18" Michelins in light snow. Also got a DIC warning of "possible ice" -that is a first. All in all a great car with all the safety features and outstanding comfort for passengers. Thank you Bob Lutz and GM Europe/China for a well designed vehicle.
http://www.imakenews.com/royalmooretoyotascion/e_article001908620.cfm
I do use a bit of extra caution to look around those A pillars. It is quite hard to tell where the front or rear of vehicle is, but thankfully I have both the camera and the screen. In reverse it shows me a yellow warning triangle which is placed on screen where the close object is. Also it has an audible which increase in speed as you get closer to the object and when dangerously close the triangle turns red. This is nice, perhaps nicer than the camer itself. Clouds of exhaust condensation obscure visibility and it is even worse after dark when light is reflected into the camera. Also if the sun is bright behind you, that is trouble. And there are issues of bright light hitting the screen. Certainly some things were not very well thought out.
As to headrests, I could not agree more. Unfortunately this is the result of the government safety nuts as well. Elsewhere I had posted a link to the hearing on the subject with final ruling. The government idiots refused designs that have proven to meet the requirements such as automatic headrest systems. The government idiots wanted uniformity. You can complain to your manufacturer but what might be more effective is to complain to your Congressman and Senator and hopefully we can get the government to fix this issue they created.
BTW, I noticed a new Lincoln near where I parked. I had to look. If you chopped a foot off each end you'd have a hard time telling the bodies apart, aside from little trim pieces such as the chrome strip in the rain gutter on the roof. The interior appeared to have the same seats, including the terrible headrests angle. I think the Buick looked nicer on the interior but would have to be in one to compare adequately. I did notice that there was one feature not available on our Buick, it had sensors on front bumper, likely part of another collision avoidance system.
All our GM cars ('04 and up) do this when the temp hits 37 degrees.
Tires are of course still a big issue when it comes to road conditions. I find the GY very lacking, especially on light snow or worse.
I have no idea what those doing figure 8's were rolling on.
“A BMW 535i sedan, loaded with options such as navigation, adaptive cruise control and night vision, costs about $60,000. The vehicle is highly rated and is powered with a 3-liter, six-cylinder engine. Buick's 2011 LaCrosse, with a 3.6-liter engine, navigation, leather and other options costs about $40,000.
U.S. sales of the LaCrosse this year have more than doubled to 56,038 through the end of November, compared with 23,237 a year earlier. Sales of BMW 5-Series sedans, by contrast, have fallen 4.7 percent to 33,746 from 35,392 during the same period.
I've driven both of these estimable sedans. Amazingly they're quite comparable in terms of comfort, performance and handling attributes, even though the BMW costs roughly 50 percent more than the Buick. But years of image-building by BMW have produced an intangible sense that one's status is elevated simply by getting behind the wheel.” Read more at http://money.cnn.com/2010/12/21/autos/Buick-LaCrosse-luxury-GM.fortune/index.htm-
These devices can be highly accurate, is the one on our vehicle?
I was just throwing out stuff that could be added as safety items and an attention getting sound. I think mine has come on while driving and encountering the preset temp, but again you are left to guessing when freezing will occur. But then the same if roads are salted, but then salt stops working at around zero degrees.
Once you've gotten the power of computing, then it is just adding circuits with the proper software.
I have to question the accuracy of the sensor used since it is also part of the automatic temp control and mine swings wildly. But now I will try to learn if it occurs with onscreen temp display. Thanks.
Reading your posts, it seems you are suffering from paralysis thru analysis. Try to keep it simple...KISS.
Anybody know if you can add the side impact warning system if the car doesn't come with it?
I don't have the side warning system although my wife wishes we had it. But I thought it only covered the passenger (right) side of the vehicle. If that's the case it wouldn't have alleviated your problem. Others who have the system may correct me.
I allowed my son-in-law to do some of the driving on the last trip. He knew of the system but obviously working with it as a newbie. Consequently he was spending too much time checking the passenger side mirror when traffic in our lane came to a stop. I called out and avoided a new front to my car. I can see where that front sensing system might have value.
Perhaps if you can get wiring/system diagrams you can learn the needs or what is changed with this feature. If you are a bit of a do-it-yourself guy you might be able to get the parts from a junkyard. Wiring will be an issue though because it might have been incorporated into the main bundles when Buick decided to add it. If it is added wiring harnesses and other parts you will more likely have success. And you may be lucky enough to have all the needed wiring or part of it.
I think this system was part of the driver confidence package. From the beginning of the 2010 model till now there has been a large number of changes as to what was standard at a model level and available as an option.
An added thought. This site,
http://www.c2e.info/rpocodes/
and there is a dedicated GM forum where they can give you the three letter codes that are specific for this option. They might be necessary when looking at wiring diagrams to determine what is applicable.
Good Luck. I hope you have success.
That is the way it is supposed to work, but mine does not. I actually see some people adjusting the setting up or down thinking it will heat or cool car quicker, but that should not be if it is working properly.
Mine will be fine for a period of time and then it suddenly becomes to hot or too cool forcing me to change setting.
And because bad smells enter with what is supposed to be a CAF, I have to suspect there is a common cause.
BTW, as you point out, measuring temp is not rocket science, yet I see these signs posting temp all over town and they seldom agree with my display.
I have a laboratory thermometer somewhere and will compare when I find it.
Same is true for the rear warning system, but not quite for the camera.
Overall a great car choice with whatever engine/trim level you chose. Only one guys opinion, but GM 2010 sales are up 7.5% with total industry up 10.7%.
http://www.gminsidenews.com/
Is the pressure displayed on DIC or are you reading it with an accurate guage? After a lengthy run to warm tires, what pressure is displayed?
I have the CXS Touring Package and the ride seems to be softening a little at 5600 miles. But I still believe I hear my noise from road and suspension than this vehicle should have. Over 3800 miles of highway and loaded vehicle may have helped breakin the suspension.
I'm still of the opinion that this vehicle should have had air load leveling on the rear.
great car so far- waiting for long term quality with this new model. Price wise- the CXL is a good choice of cost versus value of upscale options.
good luck.
Are you running in sport mode? That is, are the 19" part of touring package or a separate option?
Everyone with the touring package has been getting GY tires and I'd bet they are part of ride issue as well as noise, poor in snow, and not the best on wet road.
What is cold inflation and are you monitoring it closely via DIC?
Choppy is how I might have defined my ride on a 96 Olds Aurora when the pressure was too low. Tires I had on it were a bit soft in sidewalls compared to GY and some Michelins. The result was that not enough of the impact at surface was immediately passed to struts and less valving would open to properly handle rapid movement. Yet compression of the sidewall would take longer to fully release resulting in choppy bounce of sorts. Too much air and every small road defect would try to pass through, so I had to hunt a sweet spot for ride. That vehicle and Cadillacs were the reason RFB were created. The bodies were very stiff compared to other vehicles and would pass slight tire imbalance to the passenger compartment.
I guess I'm happy I missed that time since they later added other options not previously available such as SBZA. At the time of my ordering, the Touring package was not available on CXL, but I believe it now may be an option.
I compared the price of CXL with options added to bring it to level of CXS and the price was quite close, but still missing some standard options that came on CXS. Also they did away with 3.0L by the time I ordered. And that may be a regret with gas prices steadily climbing.
Does your guage agree with DIC pressure? If you are reading a garaged temperature that might be why you only see a 2# increase. If mine, 19", are read at ambient temperature for cold, I consistantly see a 3# increase once thoroughly warmed.
Also posted earlier that we wanted 3.0L in lieu of I-4. 3.6L is a great engine but we went for the 2010 CXL at the time for total cost/benefit of the package. GM used the 3.0L in other models per prior posts.
Wonder how the actual mileage is on the I-4's in 4400# vehicle?
Yes our cold gauge (Accutire) reading is 3# less than the hot readout on the DIC and it is pretty close to DIC. Also the painted 18" alloy wheels seem to hold air in cold temps but we think that is the Michelin tire bead as much as rims - chrome plated GM rims seem to do better in the past IMO.
I know it sure confused me, the changes they made during the year. And wonder if GM sales and production were confused or had their wires crossed.
Just checked on the weight and they are still confused.
Specs from
http://www.buick.com/vehicles/current-vehicles/lacrosse/features-specs/dimension- s.html
did not show 4 cylinder on CXL. And the weight is really nuts. I knew the CX was quite a bit lighter when it was available with 3.0, before 2.4. I think they have not corrected it since changing to the 2.4 and shown as 3829 lbs.
And the CXL 4196 lbs, not saying if that is for AWD or not. But check this, the weight shown for CXS is now 4045 lbs. That can't be right.
Knowing how mine performs in quite hilly or mountainous areas, I'd think the 4 cylinder would not be up to it, not without it constantly shifting a lot and bogging down. When mine was loaded, it bogged a bit before downshifting. Load that four cylinder with four adults and cargo and it will surely have to work even with lower ratio final drive.
Cadillac tried a 4 cylinder and the brand suffered, so it seems they said only V-6 in Cadillac - no I-4's. 3.0/3.6L production had to be constrained by CH XI and downsizing so once again, Cadillac wished and received.
The shifting pattern is a function of the new 6-speed and the economy first shift RPM programming as you know. We use the manual shift option on big grades to avoid the searching that results from the economy priority. We had a 98 bonneville that had to be flashed (reprogrammed) due to bad code in the shift sequence program. Same quick upshift and slow downshift but wider shift points (due to 4-spd & 3800 engine) so no searching.
GM will figure it all out and come out with TSB's at some point- but OK for now. Great vehicle for a great price. Enjoy!
In terms of tire pressure I did not fare as well. The pressure in all tires dropped to 30 psi, a larger drop that I had expected and so far I have not noticed any adverse driving characteristics or out-of-round tires. The handling is the same as before though.
On a side note, my rental car while on vacation was a 4WD right-hand drive Suzuki Escudo (Sidekick). They drive on the left side of the road so at times it was a bit unnerving on some of the small and mountainous country roads. But I enjoyed my Sidekick nonetheless and perhaps will consider buying one for some fun driving around town.
Happy New Year to all and feed the forum.
Winter is here with a vengeance and we are buried under almost two feet of new snow upon the 20 inches two weeks earlier. But my Lacrosse is undaunted. Press the push button start and the engine roars to life in an instant. The heater, on automatic setting, heats up the cabin very reasonably quickly, albeit a little slower and louder than my Avalon. However, with heated steering and heated front seats the Lacrosse is truly a climate control environment.
Nonetheless, compared to the heated steering, the seat warmer is much too slow. It takes about 10 minutes before you begin to feel the warmth. That was also true in my Avalon so I would have to conclude that might be due to an engineering limitation.
Don’t know what GM can do next to improve the cabin environment but I am pleased with how the Lacrosse tames the harshest of winters and hottest of summers.
Happy motoring to all and please share your winter driving experiences.
