Hyundai Veracruz Tires, Wheels and Suspension
in Hyundai
Anyone know when Hyundai moved to Hankook tires on the Veracruz?
I picked my GLS up on the 4th of January and it was equipped with Hankook Dynapro HP's.
I see in other threads mentions of Kumho's on the GLS and Michelins on the SE and limited but no talk of the Hankook's.
So far the ride seems quite smooth on these tires. 44 max psi and I am running them at 30 psi as the dealer suggested. I might move them up to 35-36 psi just to test how the car feels at that tire pressure.
Seriously considering the Veracruz.
What is the difference between these two tires in regards to noise feel etc?
Is it worth the extra $?
Thank you,
Chris
- 18” 5-spoke alloy wheels
- Power driver seat w/ power lumbar support
- Auto dimming interior mirror with HomeLink® Universal Transceiver & digital compass
- Auto dimming exterior mirrors
- Leather-wrapped steering wheel & shift knob
- Automatic headlights
- Roof rack side rails
- Fog lights
- Cooled front center console storage
I like the roof rack and fog lights, but not sure if it is worth 1700.
There have also been numerous reports here that many peoples cars were delivered over pressure, not once did I see anyone mention the TPM on.
The question is... What happens between 30 psi and 44 psi? Has anyone tried running at, say, 36 psi? According to what I've read, the tires should run cooler, give better mileage, last longer, but give a slightly harsher ride and less traction. Some drivers (of other cars) say it improved road feel.
If you try other tire pressures, please post your results here.
It is a hefty investment...but in the long run, you'll save. First of all, when driving in winter, you'll save your All-season tires the wear & tear from spinning and all. Second, think about your insurance premium going up because of a minor fender-bender that could have been avoided if you only had invested in winter tires...and thirdly, safety to you, your family and others on the road.
I will never drive a car without winter tires again! 18" are very expensive...so was my VC.
AWD is good for "going", what's stopping you? All-season tires? Gimme a break.
Actually, its a good excuse for buying nice wheels for the VC next summer, I mounted the winter tires on the stock wheels and will buy nice summer wheels for my all-seasons.
-That's what I said :shades:
Friend of mine with a FX45 has the same issue...those things should take into consideration stuff like outside temperature and tire temperature IMO!
Hell no! I think they're absolutely great cars.
If you have a flat tire removed from the wheel or a new tire installed by a non Hyundai tire vendor be SURE and warn them about the sensor.
The air powered mounting machine can ruin the sensor when the metal dismount bar sweeps around the wheel.
After one week, so far no problems with TPMS light.
My wife and I love the car, and now have 10,000 miles on it.
Keep in Cruzin!!
My 08 VC Limited had about 1500 miles on it when purchased (manager used it to & from work). It has performed more or less flawlessly in the intervening 10 months. I have, however, noticed gradually increasing tire noise/ vibration at highway speeds. After a 700 mile road last week it was annoying enough that I took it to a good tire/ alignment shop to get the tires rebalanced.
After inspecting them, the mechanic pointed out that the inside edges of the front tires were badly cupped, which probably caused the noise & shakes. He insisted the problem wasn't balance or alignment but a problem with the front suspension and I would be well advised to take it to the dealership for a warranty repair.
I'll caveat here by saying I never rotated the tires in 13000 miles, but feel that if I had rotated them, I'd now have 4 cupped tires instead of 2.
I'm inclined to trust the mechanic's opinion because he had the opportunity to sell me $100 worth of bal. & alignment but didn't.
Before I go face the dealership I was wondering if any of you have had similar experience?
Thoughts?
I'm from the 'old school', and here is my opinion for what it's worth.
Years ago an old mechanic where my father brought his car for maintenance, said a 'rule of thumb' is tire pressure should be double the rim size. Therefore, my Limited with 18" wheels has 36 lbs even though the door label indicates 30 lbs. I have never had any problems in 50 years of driving using Charlie's 'rule'.
SnowTires:
I lived in western MA and used to put 4 snow tires on my cars and never had a problem when I tried to stop or turn a corner. I have seen cars continue straight ahead when the driver applied the brakes and tried to take a corner. Enough said!
I am getting a package deal of 4 STUDDED snow tires and wheels for my Limited, but I am getting size P245/65R17. Take it from an old guy who has never been stuck or out of control in the snowy Berkshires.
So, here you are with my unsolicited opinion, and yes, I know the 17" wheels are OK because the GLS has them, and the 18" wheels are just an upgrade for the SE and Limited.
After 12,000 miles, my tires roared so loudly that I could not hear the radio. I had Michellin check the tires and they said they had never seen tires worn this unevenly.
The tires were trashed due to the front end being so badly out of alignment the day I drove the car off the lot!
Per Wal-Mart (believe it or not) they reccomended trying to re-mount the tires on the rims in the opposite direction as a last attemp before I spend $1100.00 on new tires.
It worked like a charm. I now have 59,700 miles on the Michellin Latitudes though I will be replacing them in the next month. The roar went completely away and the tire wear issue evened out over a month. I did have to have the car aligned a the dealership though.
I am hearing from others that this Model Hyundai is difficult to keep aligned!
Good Luck
My first thought was the wheel alignment and balance, got both of them taken care of but the problem persists. Any thought??
How much was the alignment off? Did they provide you with a copy of the printout? If the struts and shocks are not leaking, I am not sure how to prove that they are weak and the cause of the tire cupping. Discount Tire will now be watching my new tires for signs of improper wear as I don't trust the Hyundai dealership to catch it in time.
My wife drives the vehicle to and from work ( highway miles) , and the repair tech suggested that pot holes or bumpy roads would cause the misalignment...
Needless to say, all of this occurred prior to reading this forum. I did pay for the alignment. Now, I'm feeling a sense of being taken advantage of. Furthermore, I am concerned that this will continue to be a costly process. Especially, the wear and tear on tires and having to replace them often.
If you don't mind me asking, what was your outcome and what recourse have you considered?
I am still getting the cupping which started to occur at round the 30,000 mile mark then has gotten progressivly worse .
In my 20 years of being on the road and going through a Passat, Volvo850, VolvoC70, CamaryXLE, and a Altima.......I have never had the issues that I have had with the Veracruz Thanks to the warranty most of them have been taken care of 2 sets of bearings, sway bar links, viscus coupler, hub assembly.
Now I am scheduled to go in an have the struts and shocks replaced. I really think that this vehicle sucks in regards to anything that is attached to the wheels.
If there are any Mechanics out there that can chime in I would greatly appreciated it. There are not even any after market products to replace the faulty Hyundai products. I am returning to either a Toyota or Nissan.
:mad:
I completely blew one of the tires on my Veracruz. Ordered single replacement tire (tires were almost new, almost no wear), however when I got home I realized that they actually sold me very similar but not exactly the same tire. So I'm now with one mis-matched tire on my car.
The original tires were Michelin Latitude Tour, and the new tire that ended up on my car is Michelin Latitude Tour HP. Very similar in look (Tour has zig-zagged sipes, Tour HP has flat sipes) and a bit different load/speed rating (104T vs. 104H).
How serious is the screwup that Costco made? Should I worry about stability of the car on the road in situations such as emergency braking in severe weather?
The vehicle is no more than 18 months old and has been in and out of the shop at least a dozen times, sometimes for things Hyundai claims they fixes repeatedly.
By the way, a lot of electrical problems and a very bad vibration coming from the drivetrain at speeds between 30mph and 58ish mph - so much so, that his wife is scared to drive it.
I checked Sam's club website and they have 14 different 17" tires for the veracruz versus only 5 choices for the 18" tires.
Your thoughts appreciated. Thanks.
Thanks for the posting. I'm going the dealer armed with your findings. If you have any additional info. I would appreciate knowing. I'll keep you posted.
It's the first problem with this car, which I have found heretofore trouble free.
