Hyundai XG300/XG350 Maintenance and Repair
in Hyundai
Ever since I got my 2002 Hyundai XG350L, the oil light has faded in and out. It will be totally off for days or even a week at a time, and then it will be "on". I say "on" because it never just lights up like any of the other lights. Rather it blinks ever so lightly as i'm driving. When I accelerate, it goes off completly, and when I brake or idle, it comes back brighter.
I know that the bulb/LED for my oil light is working, because when I start the car, the light has full solid brightness.
Does anyone have any idea why this light would be fading in and out, and sort of blinking slowly? It never reaches full brightness, and the car doesn't drive any differently when it's on.
By the way, I did get an oil change just to see if that fixed the problem, and it did not.
I added an aftermarket CD changer in 2004 -- so it's wasn't clearcut to me that it was the radios fault.
In any case, I am now replacing the radio with an JVC KWXG700 - getting mp3 capability is a good trade off.
I just replaced rear struts on my 01 XG (80000 miles) because of the suspension noise. It cost me $650 but made a huge difference. The suspension is sophisticated and soft sprung (for that floaty ride) and 60-80K is what you'll get from it, lesser if you live in NYC.
A very nice and knowledgeable person in Texas told me that it might be that the radio is a false front and it really isn't that big and there are things behind it like duct work that necessitates an overall smaller radio.
What do you all think?
-johnny49
This does NOT happen after I get more gas, and I have checked that the gas cap is closed and clicks multiple times.
The Hyundai dealership wanted $95 just to diagnose it, so I was hoping someone here had a magic solution for the problem. Any ideas?
Have you replaced the rear struts for another reason?
I take it this is a common design flaw with this car?
SONOTAV6-2001-54K miles
BOTH CARS REFUSED GAS! my xg went just last year.. got a sensor replaced.. not the one listed above , but another one.. the Hyundai in Melbourne Fl knew what it was right away. not sure it was real cheap, but also not sure i couldn't have dont the replacement myself...
When this first occurred I was told the repair was to be around $350 to $400 as they would also have to replace the "valve". I waited a few months and saved up before taking it in. The bill was $798 due to the fact that the cartridge had disintegrated and the lines has to be cleaned. Then it still didn't work so they had to replace the "flow valve" on the gas tank by removing the tank. This added the additional $250. The engine light is off, the new cartridge is in place, the lines have been cleaned and both valves have been replaced. It works fine now. As it is an emissions control item, it was not covered by the warranty.
I cannot provide you with Valve part names and numbers due to the quality of the ink on the print out - it is not readable. Sorry. But thanks to this Forum, I know that this is a common problem with this vehicle at this age with 57K miles on a 2002 car.
this could also be a wirering,fuse problem but I'm not sure.
help
the problem that i'm having with my xg300 is with the passenger side speaker volume. if i have the balance positioned in the middle, i can't hear any sound from the passenger speakers. if i move the balance entirely to the passenger side, i can get very low volume sound with no distortions.
has anyone else had a similar issue? does anyone have an idea why both sides are not outputting volume at the same level?
any ideas or suggestions would be greatly appreciated.
Orv2.
Orv2.
I took the car to a shop (not Hyundai dealer-it's out of warranty) who was unable to locate a problem or duplicate the issue. My wife picked up the car and drove it home today without problems. I did some research and found that some owners have had similar issues and ended up replacing some sort of sensor: accelerator position sensor, accelerator sensor, accelerator relay or something of the sort. I called Hyundai Consumer Relations to explain the issue and he told me he could find nothing showing a re-occurring issue.
Does anyone know what the problem is or what I need to replace?
Luck,
orv2
Orv2
P S A P S location at passenger side near the fire wall.
Good Luck
