2002 LS Cooling Fan Alway Running... and Loud
                    My 2002 LS radiator fan is always running and very loud.  Does not matter if the engine is hot or cold.  To me, it sounds like a fan speed control is stuck in high speed mode.  The engine temp sensor appears to be working ok because the temp gauge is working properly and the engine is not over heating.  Any ideas on what could be the problem?
Sensor? Change coolant? Air Bubble?
You might need to replace the hydraulic fan with an electric one.
