Volvo XC90 Lights and Headlights
Hello everyone,
The headlight lenses on my 06' XC90 have developed many scratches and a pitting (almost a mild sand-blast effect) in some spots and I was wondering if anyone else has experienced this.
I have not had the car into brush or anything else that I can think of that would cause this and I don't see any other cars here with this problem.
Volvo says that each lens would cost $1000 to replace so I'd appreciate any ideas or fixes.
Has anyone else had this problem?
Seems to be a common problem - I just got it too.. Most of the time after I start the engine my left headlight goes out after 5 sec. Can you please tell me the part number so I can order the repair kit without facing the same problem like you with the Volvo dealer. Many thanks.
My question: Is this related to the electronic control problems others have had? Could my problem have been resolved by replacing the electronic control system for the lights, or is the ballast control the same thing?
Hi pageeantmom, Do you have the part #?
I can't believe it is the bulb. Could it be the switch? Wiring? Any suggestions so the repair guy doesn't rip me off?
It is a 2004 XC90 with HID factory lights
So I recommend asking about the baffle.
Any help? Thanks
Thanks. :lemon:
Try looking on Tmart.com and search D2R Xenon Bulbs.
These are the type for a 2004 XC90 of which I have.
I am currently experiencing headlight problems of my own.
Replaced a bulb purchased from Tmart last and has now failed and now getting the dreaded Low Beam Bulb Failure message.
2004 XC90 only have one main headlamp bulb as serves both the low and high beam function as the headlight bucket rotates slightly upwards to provide the high beam function.
Hope this helps all who read.
