Kia Rondo Gas Tank overflowing
in Kia
I have a 2007 Kia Rondo that has had a gas tank overflow problem ever since I bought it new in May of 2008. When I pump gas I cannot set the pump to automatically click off because it will not go off until about 1/2 gallon of gas has already overflowed out of the tank, down the car, and onto the ground. Not only is this not environmentally friendly, I fear it is bad for the car as well. I asked Kia about it and they said they have had no other complaints and it just must be the pumps at the gas station I use (though I told them it does it at every station I use). I don't mind pumping the gas manually, but the tank holds 15 gallons and I have to slow the pump to a crawl at about 13 gallons to make sure it doesn't overflow. Anything faster and it just bubbles out. I can't even wash my windows anymore at the pump because I have to be vigilant about pumping. Anyone else out there have a similar problem?
This was interesting.
http://www.straightdope.com/columns/read/230/how-does-a-gas-pump-know-to-shut-it- - self-off
came across this article that may help clarify how the pump works:
"How does a gasoline pump at a filling station know when the tank is full?." 01 April 2000. HowStuffWorks.com.
This mechanism has been around for a long time, so it is safe to say there is not a miniature camera inside the nozzle hooked to a microprocessor. It's purely mechanical -- and ingenious.
Near the tip of the nozzle is a small hole, and a small pipe leads back from the hole into the handle. Suction is applied to this pipe using a venturi. When the tank is not full, air is being drawn through the hole by the vacuum, and the air flows easily. When gasoline in the tank rises high enough to block the hole, a mechanical linkage in the handle senses the change in suction and flips the nozzle off.
Here's a way to think about it -- you've got a small pipe with suction being applied at one end and air flowing through the pipe easily. If you stick the free end of the pipe in a glass of water, much more suction is needed, so a vacuum develops in the middle of the pipe. That vacuum can be used to flip a lever that cuts off the nozzle.
The next time you fill up your tank, look for this hole either on the inside or the outside of the tip.
Not only is it a waste of a highly precious commodity, but it is bad for the environment and my wallet.
Oh and I have 42,000 miles and this started about a year ago at 29,000.
When they solve the problem. I'll post the solution.
My soon to be wife has the same issue with her 2008 Sonata. At first, I admit I was thinking "girl at a gas station, geez". I promise I'm not usually a misogynistic dude.
Anyways, pretty soon there after, my 2007 Jeep Liberty started doing it. Im relatively certain that one car didnt "infect" the other (its not a disease) and its pretty odd in terms of probability, so I started searching. IMO, there's no way its the car and these dealers are doing what dealers do-- ripping everyone the crap off.
IMO, its likely a pump issue not a car/user issue.
