1995 Ford E-350 7.3 Diesel Bogging Problem
I have a 1995 E-350 7.3 Diesel. For about a year now and 30k miles, I have had a bogging problem from time to time (sometimes every hundred miles, ten miles, or 2k miles). The thing will be running great down the highway and all of a sudden it will start loosing power until you can't go even 40mph. When this happens, you pull over, shut off the truck, start it, and it runs great. Sometimes you have to do this a few times before it kicks in. Every once in a while if you drive it long enough and baby it , the truck kicks back in up to normal power. Before having this problem, I did have a new transmission installed. I have had it into the shop where they have replaced a Cam Positioning sensor as well as in intake sensor. It seems like the problem is getting worse and is happening more frequently. Any help?
Brady
flattracke12m@yahoo.com
Brady
1. Try replacing the IDM module. Its a little box on the right fender near the air brake assy..that is the module that controls the the injectors.
2. The powerstroke engines has its own hi pressure oil reservoir that builds up hi pressures to open the injectors.. over the years the oil tends to sip away.. The hi pressure oil reservoir is located front top section of the engine just beside the aircon compressor. remove the airfilter casing and unscrew the pressure switch on the left side rectagular oil reservior. There is a filler plug on the right but it is quite inaccessible. check if there is oil, if not fill it with oil 40 and reverse the procedure then start the engine.
eddie
eddie
Every time I shift into drive it jerks and will travel about 5 feet then disengages. It does this in every Gear. I can’t travel more than 4 feet before the transmission stops working.
Any Idea How I can solve this problem?
heres the link to that hydrolic
http://www.northernhydraulics.net/dump_bed_kits.html?gclid=CI_x_5zokJ8CFY915Qodw- - Up7lA
Garry
