Lincoln Navigator Towing and Wiring Questions
in Lincoln
We just bought an 08 Nav and are trying to confirm if it has the towing package. The person we bought it from says yes, but how can you tell? Also, I need to change the flat 4 connector to a flat 5. Is the best way to cut the 4 pin connector off and splice the wires together? The 5th wire for the trailer brakes is there but obviously not connected. Thanks for any assistance!
Please let me know if you found out...
Such there be one? If so, where is it? How can I identify it (# of wires, wire colors, etc)?
I have a 2006 Navigator with a factory installed towing hitch. I've been to two Lincoln dealers who have told me the same (6000lbs-8600lbs) I'm looking into buying a travel trailer that has a dry weight of 5500lbs and is 33 feet long. Can my car handle this?
Thanks for your help!!
The Navigator we have with the heavy duty package has the RV electrical hookup to the upper left of the receiver's location while the regular straight pin hookup is located below in line with the receiver.
