2002 Lincoln with 187KM's not mileage should i buy?
in Lincoln
Hi I am looking to buy a car and I came across the Lincoln Ls I was wondering if the Km's were too high? Also it runs good had some work done to it like new ball joints suspension arms. Also are Lincolns reliable and easy to fix or cheap? Please help thanks
Leaky valve cover gaskets (think this was a V8 issue mainly)
hydraulic cooling fan
COPs (coil on plug ignition)
HVAC controller/blend door
Transmission valve body
The good news is that you'll save enough on the price of the car relative to other similar cars that it will pay for a lot of repairs down the road.
If it runs good with no hesitation or misfires or loss of power and the cooling fan seems to be working and the transmission was already replaced then I'd say it's worth the risk. But no car is perfect and you could have a few hundred dollar repair at some point.
If you know a good independent mechanic ask if he would work on it. Anything done at a Lincoln dealer will be expensive. The guy who works on my cars has worked on a lot of LS's and has no problem fixing mine.
Add to that the need for very "special" coolant burping procedures, window regulators that fail monthly, an automatic transmission that, well, requires a Ford engineer to even begin to figure out how many ways it can go south, plus many other things, and one ends up with a pretty miserable situation. If the car had continued into production beyond when it did and actually sold large numbers, people would have learned how to work on it, plus which the flaws would have been worked out.
Well, that didn't happen.
I'm still in possession of one I bought (special order to get the manual transmission) nearly 12 years ago. I need to unload it in the next few months, but I'm not looking forward to the experience.
Yes, that's what I'm hoping for, but I don't want to make a career out of looking for the 12 people on the planet who want my car.
I'll put it on Craig's List and put up with the BS that is almost certain to result.
There could be a real car nut in the mix, but mostly I expect the other kind.
