Honda Insight Engine Questions
in Honda
Was just wondering, if anyone has ever had an issue with the Engine Idle feature on the Civic Hybrid or Insight, and the engine did not re-start at a stop light, and if so, what happens then ?
Does the battery take over so one can pull over to the curb or are those with this system stuck in traffic ?
Thank you for those that are in the know.....
Also looking for a los angeles CA Honda repair suggestion!
thanks, Cary
1. Tune-up. New plugs
2. Top engine cleaing.. remove carbon
3. Replaced LAF, 02 sensor.
4. Went back to dealership, told them that problem still exists, they did a complete analysis, and told me that they could find nothing improper.
Any further suggestions on what, or how to solve the problem, would greatly be appreciated.
Thanks..
Acetone is very dangerous to handle and hard to pour. Use a stainless steel turkey baister (Crate & Barrell), dip it straight into the acetone can, then draw it out full and empty it into your tank. Very clean and few or no spills. One dose is about the same as the 3 oz. recommended at the website. Good luck.
If the AC is off, the auto stop remains until you release the brake.
Yes, this is normal.
Daniel
The owners manuals lists a number of reasons the auto-stop does not engage. Some of them are listed above. I found the engine restarts 18 seconds after stopping. After a lot of testing, I found if the ventilation system is on, the car restarted in 18 seconds. Like clock work. But, if you press the off button and shut off the ventilation system (the screen goes blank) the engine stays off until you let up on the brake.
