2006 Chevrolet Cobalt
treehugger81
Member Posts: 2
in Chevrolet
Hi we have a 2006 Chevy Cobalt. The engine is a 2.2 according to oil change records (hubby is gone and I know nothing about cars). It has around 56,000 miles on it. All of a sudden several things have went wrong with it. I don't know if they are all related or not since I know nothing about cars, but since they started happening around the same time I assumed they were. To start with we started losing coolant. My hubby keeps filling it up. There is no coolant in the oil and none visible on the ground. Then it started running really rough when starting up. The sound it is making sort of reminds me of when we had to change the oxygen sensors in our old van. Then just the other day we started hearing a noise under the passenger side. It sounds like water sloshing around in a tank whenever he has accelerated and then suddenly stops. The check engine light came on around the beginning of all this and whenever we had the mechanic hook it up it said it was a knock sensor. He changed that and a week later it still hasn't done any good. Our check engine light is no longer on, but it still sounds rough, is losing coolant, and the sloshing water sound is still there. If anyone could give me some helpful advice or suggestions it would be much appreciated. Thanks!
Has anyone else had this problem?
PS. I have also had my Control Arms replaced twice, and have had the problem with the car stalling at red lights. I have had the fuel tank, and multiple sensors replaced. The outside temperature gage always gets stuck, and it will say 85 when it is 30 outside. I now have 60,000 miles on the car, and it drives like crap.
I can not wait to get a new car!
Help please
I suspect you'll find it's much cheaper to have it cleaned and resealed with a seal or with silicone.
I'm not sure what you're asking then. It's a car. Things sometimes go wrong on cars that are minor. Sometimes things go wrong that are major. You get them fixed and go on with your life.
