Jeep Liberty Rear FLIP-UP GLASS will not close
I have 2006 CRD and the rear FLIP-UP GLASS will not close. It appears the LATCH on the swing gate is in the closed position. I don't how the LATCH transitioned to the closed position while the FLIP-UP glass is open.
Any ideas?
Any ideas?
Now I am having the problem this time with just the glass not wanting to latch back down (no surprise automatically opening - just wont latch) What I have to do to make it be able to latch back down is to use the back window hatch button on the jeep key fob and this will trigger it to flip into the open position so that you can relatch it back down. I have yet to call my dealer to see if it is still covered from the last time they replaced the defective part.
Found my paperwork - 2-1-05 said removed rear gate handle and found switch corroded. Replaced handle assembly with new switch.
This was for the hatch not shutting. 4-28-05 Checked and found wiring connector at release motor had loose terminals. Secured terminals.
I am having this problem again, guess I should have someone check the terminals again!
Hope this helps.
