Lincoln LS Rough Idling and codes
                    I'm trying to figure out why my Lincoln lS V8 is idling so rough, I was driving it today and the check engine light starting blinking, I was about 5 min. from home so I drove it home and had a friend come over and read the codes. The codes P0136 " Circuit Fault" P1000 "System check incomplete" P1131 "Sensor indicates Lean"  P1137 "System indicates lean" and finally "Injection 1 and 3 fault"  From what I have read because of the two Injection faults that can cause the codes for "Sensors Indicating Lean" to go on. The computer did not show misfires, just showed faults for 1 and 3. What could this be? how would I go about to looking for the problem. Thanks in advance.
P1131 Indicates Lean means though...
http://picasaweb.google.com/lh/photo/H3tJLMs9mLCpKJci6Bu_zw?feat=directlink
The ETC failsafe mode could easily be caused by an electrical problem and could be moisture related. If it doesn't reoccur I wouldn't worry about it.
I found this thread on Sunday. I ran it up to AutoZone to have them check the codes. They found a P2104 and P2112 code.
I took it to the dealer on Monday and they replaced the #5 coil, this time they already knew it was covered under the program. I spoke with the service manager and talked about this may be a challenging problem based on my research. He recognized that once one coil goes it might there is a tendency for more of them to go but he could not replace them all and get it covered. At least they didn't say it was the throttle problem (which isn't covered under a program).
I guess now I have to wait and see what else goes wrong and how long in between. I ask what codes the dealer found but they never have them available when I pickup the car. I'll keep checking this thread and post any updates...
ford was not the first to use plug through head design (not even the infamous HEMI of yesteryear was the first ,but they leaked to!) the dodge 2.4 has an aluminum valve cover and they leak like a sieve because aluminum expands and contracts at an unbelievable rate where as 'plastic' does not.hondas are notorious for this to.
your car with the 3.9 isn't even realy a ford ,it's a jaguar and anyone that knows cars knows jags are money sucking cars that rarely ,if ever, run proper ,your blaming the wrong company.
i guess if you don't like fords 'better idea' then go buy a Cadillac cts (same class of car) or a 300m and you can experience REAL problems and you will look back at how cheap to maintain and repair your ls was (caddy cts 3.6 40k miles ,timing replacement after they changed oil and used conventional oil instead of full synthetic....$3.500)
the trick to owning any luxo car (cept for the old Lincoln town car) is the same as owning a corvette....buy 2 so you got one to drive while the other is in the shop!luxo cars are only good for about the same time as there warrantee then they start to degrade fast,people who buy these cars new trade them in every year or two so why bother with longevity?ALL car manufacturers do the same, even imports.
if you want durability and cheap repair bills buy a taurus,you bought a high dollar status symbol for a car get used to paying to keep it up.
