Cadillac SRX is a LEMON
Does anyone have an attorney to help work with Cadillac. I brought the 04 SRX brand new and have had nothing but problems. Now that the warranty is over they won't even help, even though the problems started early on.
1-Catalyc converters replaced 3 times
2-transmission rebuilt
3-replace engine brackets
4-replace engine flexor plates
5-replaced water pump 2 times
6-loud vibrations- told to replace tire- that didn't work
7-whinning noise- told belts may need to be replaced
8-loud cracking noise from sunroof- told normal because of size
9-NOW- being told need new throttle system!
Each one of these repairs if in excess of $1000!
You should make your email address visible in your member profile if you wish people to contact you. We prefer that contact information (attorney names, phone numbers etc.) not be posted in the Forums.
SUVs and Smart Shopper
Starter, seat heater elements, airbags, rear door latch, cam position sensors, coil, transmission cooler lines, transmission cooler, transmission lines, the transmission itself, power steering hose, transfer case seal, front axle seals, rear axle seals, differential seals, mirror dimming fluid seals, catalytic converter x 2, shift kit, valve cover gaskets, timing chain cover gaskets.
2 1/2 weeks, less than 500 miles after the the timing chain / valve cover and differential gaskets are replaced, the engine seizes up on the highway. Our warranty expired (by time not mileage) 2 week before the engine seized.
Contacted GM "goodwill" customer service and after 2 weeks was basically told to take a hike. We had 89,000 miles on the car. We have filed a complaint with our states Attorney General
To top it all off the engine for this car was specific to the year. Even a used engine
is 3 times the price of the newer 3.6 liter engines. IE: $2250.00 for a used 04 engine with 70K miles VS $1900.00 for a new factory wrapped engine for the 05,06,07,08 and 09 model.
Although I have always been a GM fan like my father before me, they are not the company they used to be. I will NEVER purchase another GM product and strongly suggest that you don't either.
:lemon: :lemon: :lemon:
