Toyota Sequoia Window Problems
Rear window wont go down. Makes a lite noise when you push the window button on the dash. Whats the problem?
I just traded in my 2001 for a 2006 and when I tried the rear window on the new truck it fell off the track on the first try. The dealer is going to fix it, but I think the heavy rear window is just a bad design.
Thanks for all the info folks. It has been a great help.
http://www.toyotapart.com/Back_Door_Power_Window_Inoperative_TSB011510.pdf
I was able to fix my power rear window problem and the inoperative wiper/washer and defroster. I set up a website with photos and notes to show how I did it. I hope this helps.
By the way, I am really upset with how Toyota has handled this problem.
http://www.piranamedia.com/toyotawindowrepair/
Steve
My dealer is asking for $1,005.00 to fix the back window/defrost/wiper issue, on a 2007 model and I'm only 31 days out of my waranty with only 19K miles on board and just like you've mentioned, nobody cares, Toyota's main office or the local dealer.
Steve
ps There is a good youtube video on how to replace the rear door latch. When it rains it pours.
Thanks, AJ
of it. Well now its my problem. The rear gate does not open, window does not go up or down. The rear wiper does not work. the dealer wants over $1000 just for parts another $600-$700 for labor. This vehicle should have been recalled. The rain gets into rear regulator and now everything is rusted. I am in proces of buying used parts and will have friend fix it myself. Dealer knows its a problem but refused to address it. I refuse to sell it until I fix this problem. Any suggestions would be helpful
I seem to be suffering the same problem that is being addressed in this thread but it appears that sgoodson's website at piranamedia.com is not accessible; I keep getting a 404 error.
Is this information still available?
If not, from what I am reading, it appears that I do not necessarily need to do what the toyota tsb says, namely replacing the ECU; is this true?
In the absence of any data from sgoodson's website, does anyone have any other hints?
http://69.175.10.122/~piranam1/_ToyotaRearWindowRepair/
Hopes this helps.
Steve
One tip - I quickly realized the window was working again, but without putting the window all the way down, the other two systems weren't working. Be sure to roll your back window all the way down, then your defroster and wiper should work!
Keep it real!!
Bob
">http://www.piranamedia.com/toyotawindowrepair/RearWindowRepair.pdf
Good Luck,
Steve
I did some maintenance on my server and inadvertently deleted the files.
Here is the new link:
http://www.piranamedia.com/_ToyotaRearWindowRepair/
Steve
The typical reset/timming of holding the switch up & down a few seconds dose not recalibrate its motion.
Any body know whats up.
You should feel very good about how many people you've helped on this problem. After reading through the 5 pages it seems the link goes bad over time can you help me out with the link and reset it so I can also fix my
2005 sequoia?
Terry
In the technical bulletin #9, it says to "Remove the multiplex network door ECU. Using a drill 3.2 mm (0.126 in.) or shorter, drill out the two (2) rivet heads". Then next in #10 it says to "Install the replacement multiplex network door ECU and rivets".
Do I need a new multiplex network door ECU or just use the existing one and rivet it back on?
Please let me know.
This is what I did:
1. Checked Fuses - all o.k.
2. Tried Resetting ECU - did not fix problem
3. Removed and replaced wire harness going in to ECU - Defrost and Wiper started working fine
I did not have to touch the Rear Window Limit Switch or any bolts. I believe that when the panel was removed a month ago to fix the broken handle on the rear hatch door, that the wiring harness was not pushed all the way into the ECU and therefore no contact was being made.
After taking back apart again to triple inspect and check every single fuse, I read several posts here and tried holding the window in the "up" position to reset the ECU. Now, rear window doesn't work at all, rear wiper still doesn't work, the defroster does work, and the rear washer fluid does work ! Any ideas??
