Lincoln Aviator Air Conditioning Problems
The A/C is blowing hot air. When my neighbor hooked up a set of gages the high side was reading high and the low side was reading low. The manual with the gages indicated that the filters may be clogged. Does anyone know if this can be true and if so how would I get a diagram so I can locate the filters. Thanks in advance for your replys.
SUVs and Smart Shopper
I first noticed this problem when the right side of the vehicle was wrecked and the front fender had to be replaced.
The fan soundsike it is working fine but the cabin does not get the air. It works the same for the a/c and the heater.
