Ford Edge Front End Creaking Noises
banjoplayer
Member Posts: 2
Bought my 09 Ford Edge 2 months ago. After just 1000 miles, the front end started making clunking and creaking noises (like an old bedspring) when going over uneven surfaces or turning a hard left or right especially into a driving into a curve. Took the car back to dealership and they removed the struts and replaced both the left and right side bearing plates (brackets). The clunking noise quit but the creaking noises are as bad as ever. Anyone else have this problem? Car is going back into shop next week and am hoping someone else can help out with this complaint.
Cubby
2010 edge 7 months ago, just recently started hearing the same issues with a rattling
noise. not a big deal until a few days ago it started getting louder and I also had the
clunking noise whenever i went over speed bumps. your normal wear and tear I
though. it actually is the top strut support that's part of the metal
frame of the car. the welding points are separating from the frame. that is the rattling
noise you get initially, and it grows. hard to tell when is minor and the car is just not
moving. you can actually see the problem now in my ford edge, my welding points in the
frame have separated. I just started complaining to ford and so
far no one has taking responsibility. if more people are getting the same problem in their
ford edge, you should ask to check the welding points holding the metal that support the struts.
you will only be able to see it if pressure is put on the strut. at least until it completely
separates and bends like my situation.
