Saturn l-300 wagon has flickering lights
My wagon 2003 l-300 has flickering lights and when the radio is off you can hear the engine whine. Is this a grounding problem or is the alternating system going out? I have checked all the connections and do not see anything obvious.
Any ideas on what to check.
The wrench light comes on some times and the engine light is on constantly.
Any ideas out there?
tim
We discovered that ALL Grounds and electrical connections have to be super clean and tight. We found the connections on the battery where slightly loose and so we got new bolts and cleaned it all up. made them tight and all the bugs went away. Apparently just like a computer if there is any resistance in the circuits it messes up the computers and things go nuts. The whole car runs on computers...even the throttle. No mechanics. Try it and also check any where else you see some wire screwed to the chassis. They have to be clean and tight.
By the way, whenever something electrical fails on modern cars it usually turns out not to be the part but the solenoid controlling the part!
