But I fall back on the unanswered question:
HOW ON EARF are the utility companies going to be able to measure, and definitively quantify, the "increased usage" brought on by a few thousand EVs charging at night?
And at what point do they want to use that as an excuse to raise rates?
They're not. The impact will be so minimal, there is no point in trying. Now 20 years from now if we have 40 million electric vehicles on the road, then you'll see a blip on the radar screen. A small blip at that. U.S. electric generating capacity is on the order of thousands of billions of kWh. We're talking quadrillions of watts available.
I live in the midwest where a manufacturing plant closes it's doors and moves production to China or Mexico or India or Taiwan or somewhere almost every day. One small plant closing opens up thousands of mWh of capacity, that's millions of kWh. 10,000 Chevy Volts all re-charging at the same time only pull 40 mWh tops. It's next to nothing.
Until tens of millions of these vehicles are on the road, it's a drop in the bucket, and even then it will be far under 0.01% of our nation's electric consumption.
Read more here:
U.S. Energy
PHEVs will have to come down in price to overcome the negatives presented by the Volt.
Again, this makes the idea of a timer for charging all the more appealing. I'm sure GM has taken that in to consideration.
Can't you use your iPod to check the battery level? Or was that for the Leaf?
MODERATOR /ADMINISTRATOR
Review your vehicle
neither is the volt's generator system a hybrid, it is pure gas-powered/atkinson engine.
one could argue that the Volt is an electric car whose charging can be done two ways , but not at the same time. Can't "hybrid-charge" a volt both via plug and via gas engine at the same time, or can you? If yes, then it looks like we can say Volt is an electric car with a hybrid-charging system !
Can the Plug-in-Prius be charged via gas engine as well as plug-in at the same time? IF yes then the plug-in prius is a hybrid-drive car with a hybrid-charging system! Hybrid^2 .
according to the current terminology, if Volt's gas power went direct to the road via even a 0.0001 hp rubber-band-drivetrain, then Volt would be a hybrid.
NewSpeak can be applied to automotive tech too, though, so maybe "hybrid" has been redefined via the Brave New Dominant Paradigm People.
ps - volt badlands convoy sounds nifty. car mag is a good guess, or some raging GM Promotional Road Trip, like maybe to PAX EAST.
pps - possibly by 2014 I'll select VW Golf GTD over a Volt, but seems like their prices will be close, and I will probably "cross shop" .
They were scarce with details but they reluctantly admitted as much.
So mild hybrid in reverse. The opposite of a Honda Civic - gas can't move it by itself but does assist.
?GM said the volt had direct assist from the gas engine at some times?
I'll keep reading/googling to find more about that, maybe will ask the salescritter or techs about it if i visit the dealership to testdrive the volt some day. maybe there's a way to test it. turn off the electric motors via some software override, step on the accelerator, see if car moves.... (give it a slight downgrade where it won't roll in neutral but will roll with the slightest torque/force... maybe do it on a dynamometer at whatever mph the gas engine is supposed to assist, see if it can be measured somehow?! some car nerd out there has probably done it already!)
http://green.autoblog.com/2010/10/11/gm-yes-the-volts-gas-engine-can-power-the-w- heels/
the patents should be public too by definition - so no 'hiding' there.
also the answer to the question is all reverse-engineerable and measurable via testing now that the car is so available. (i want one!)
that article seems to be a 'prediction' from before the volt was available (?).
the GM repair manual for it would probably cost a pretty penny but might be a cool place to find the details...
whatever it is, we know the volt it has unlimited range.
no range-anxiety for owners. that's the big win...
And if the engineering is done to make the car perform better at highway speeds when a demand is made for more power, I call that a positive. If that weren't the case, we would have been hearing about lack of performance: GM should'a done this, should'a done that to make it better. They engineered it for the customer's benefit.
If this were a foreign brand vehicle, we wouldn't be hearing a word about this engineering improvement trying to landscape it as a negative.
The issue is would it still qualify for $7500 in federal tax credits. I don't think anyone will go after GM to take those away, though.
Because that's what continues the debate. Why even question it?
The Volt has become a political issue inside the US. For whatever reason it's become both a green symbol and a political target. Imports don't even come in to the picture at all.
I think the reason GM got defensive/secretive was they wanted to make sure the Volt still qualified for the $7500 EV credit even if it was not categorized as 100% EV.
For the record, I was pro-bailout and I'm even in favor of the $7500 incentive. I'd even go one step further and make it a direct credit instead of a tax rebate. Though I do think it should be phased out over time.
That is where we are opposed. In the case of the Nissan Leaf all $7500 ends up in foreign coffers. With the Volt 60% ends up out of the USA. We have a horrible history of subsidizing the rich off shore. It does not help our economy in any real significant way.
We will soon know how much of the Leaf is built here.
Nissan moved production to the USA just recently:
http://readme.readmedia.com/New-2013-Nissan-LEAF-Calls-America-Home/5595986
So now made in Smyrna, TN. The battery is made right next door, in the USA, too.
Alternatively you could get a Cube, but that uses 12 barrels of oil per year (per EPA), over a 10 years period that's 120 barrels, with our capacity limited that'll basically be all imported.
You pay $92.65 a barrel but here on the East Coast we use Brent Crude and it's $103.70 even at today's mega-cheap prices.
120 barrels would basically send around $12 grand overseas for imported oil. Of course the alternative depends on where exactly your electricity comes from.
But that $7500 helps keep $12,000 from being added to the deficit.
I'm with you on carefully placed incentives, and keeping the money domestic.
Me Too
Of the two cars in the debate, I would be more apt to buy the Leaf. If I needed a commuter car. It would get me off the fence on installing Solar Panels as well. I am not likely to live long enough to justify either.
But we get $2000 here in MD, so final price is $20,250, list price before discounts. You should be able to get it for $19 something.
I only picked Cube since it's also a 5 door, but fitzmall has a no-haggle one for $18,588. Juke would cost more, even FWD.
But...$1950 for gas per year on the Cube. You'll break even the first year even if you pay full list for the Leaf (if you can live with its range limits).
If anything that's an argument to being phasing out incentives. Drop then by $1000 per year over the next 7 years until it's gone, then let EVs compete on merit.
Sooo.... now seems to be a good time for us all to agree that Volt is a much better hybrid than any Prius, technically, in the real/engineering world.
Or you can buy a Cruze that has more USA content for about $20k less and save enough money to pay for your gas the first 160,000 miles. If you live in CA the clear winner is the Chevy Cruze.
When has that ever happened on Edmunds?
For the price, though? Especially when you remove the $7500 handicap.
Remember they put in an old tech iron block that doesn't even have DI. The gas engine is surprisingly antiquated, which is why MPG when in use is nothing special.
It really depends on how much you drive. If a Plug-In Prius has enough range for your commute, that's actually going to use less fuel. Volt is better if your commute is longer than the PIP can go, but not so long that it has to use it's inefficient gas engine for long periods.
Finally, if you have a really long commute, where the gas engine would have to be used a lot on a Volt, then a plain old Prius will do better, as Gary mentioned above.
What's better? It depends.
Another question. On the charging stations you put your CC into? How much do they charge per KWH?
I stand by my post. See next item...
That's an understatement and I agree.
I was pro-bailout also but against gifting ownership to UAW with little in cuts to salaries and against gifting to union over the payment of bondholders, including many institutions and funds, pension funds for many of us included.
The $7500 incentive should be for US companies. GM needs ability to sell Volt at lowest possible cost to be competitive with others who can sell at/below cost to gain market.
Prius will get 50mpg on regular fuel all the time.
Plug-in Prius will get 95 mpg-e for 11 miles, then 50mpg on regular gas after that.
Volt will get 98 mpg-e for 38 miles, then 37 mpg on premium fuel, which costs 9.2% more per AAA's fuel guage report as of today. So that's the equivalent of 33.6mpg if we're looking at fuel cost (and who isn't?).
So if you drive 11 miles or less per day, the Plug-in Prius meets your needs, and costs $8000 less than a Volt. It nearly matches the mpg-e on electric power, so there's no way you'll ever break even. PIP wins.
But who only drives 11 miles per day? Let's dig deeper.
22 miles per day:
PIP = 11@95, then 11@50. Weighted average is 72.5mpg.
Volt = 22@98, so still 98mpg average, it's more efficient by 25.5mpg.
But...you're saving 315 gallons of fuel, and that's assuming all that electricity is free, which is isn't. You still save about $950 per year on gas, so it would take 12.3 years to break even on the extra cost of a Volt.
If the batteries last 12.3 years.
Can we still say the Volt wins? I dunno, I think 12+ years it too long for a break-even. Too risky for me, personally. Volt still loses.
Let's "cheat" and try to help the Volt win.
Say you drive exactly 38 miles per day:
PIP = 11@95, then 27@50, weighted average is 63 mpg.
Volt = ideal and perfect at 98 mpg-e, so better by 35mpg.
38*365=13870 miles, that's 396.3 gallons saved. $1415 per year at current AAA national gas price average.
So under the most ideal of circumstances possible, however unlikely, you will break-even after 5.7 years.
I think we can say Volt wins, but what are the odds that you drive exactly 38 miles a day, never more than that? Slim....
My commute is 26 miles round trip, but my kids play on travel teams so the rest of my miles would probably be 90% in gas mode.
Now let's complicate things even further, and consider the Leaf.
The Leaf gets 99 mpg-e for 73 miles.
So Leaf beats the Volt (99 to 98) and costs less, for anyone who drives 0-73 miles per day.
If you drive 74 or more miles per day, then an EV is not right for you at all.
The Volt would be better for the first 38 miles you drove, but then worse the whole rest of the time, including trips. I went to FL last year, and will go to New England this year. That's thousands of miles without charging.
Seems for a Volt to make sense you have to set very specific circumstances, were you drive 38 miles per day as often as possible, and can wait many years to break even.
I dunno about that, what if Chrysler gets the money and builds Fiats overseas? The 500E is made in Mexico and Poland.
So send all the money overseas and all the profits to Italy.
I think it should be for investments made on American soil, creating domestic jobs.
No helping Ford in Mexico, or GM in Canada, or Chrysler in Europe.
I say this knowing it would never happen.
LOL. You would have to pick a good example.
Call it the law of unintended consequences.
They have a green agenda, offer perks. The company does the math and can't make a profit building anything here. So they produce the 500E in Mexico, lose $6000 per car, then make it back with the incentives. $1500 profit per car goes to owner Fiat, the Italian execs get bonuses and buy Ferraris and Maseratis.
The US government basically subsidizes Mexican jobs. Viva Mexico!
Screw that. Build them here!
GM makes the electric motor for the Eco models in China. Not sure how much of the Volt is domestic, but Gary seems to think a lot of it is imported.
Edit: found a Monroney, only 46% domestic for the Volt:
http://racingready.com/wp-content/uploads/2011/11/Chevy-Volt-Monroney-sticker.jp- - g
18% Korean.
Edit: motor comes from Austria. Trans is USA, so that must mean the battery comes from Korea.
Volt 46%, assembled in USA
Fusion 30%, assembled in Mexico (CVT is from Japan)
Mitsu i 0%, 100% Japan
Leaf is not listed yet, production just moved to Smyrna, but it was Japan before.
So that $7500 is subsidizing jobs overseas all around.
What if the law was re-written, and you got the same % of domestic content?
So for instance a Volt would get 46% of $7500, or $3450.
That would make sense, and encourage truly domestic green cars.
I would go for that in a heart beat. If they would have done that with C4C we would have stimulated the US auto industry a lot more than we did.
