2001 mercury Villager Sport Blower Motor Issues
tater3tater3 Member Posts: 1
edited July 2014 in Mercury
I have a 2001 Mercury villager sport. The Blower motor only works on the high speed. I have read the other blogs. But would like a more recent opion.
  • mlcheesemlcheese Member Posts: 1
    I have a 02 Mercury Villager and have replace the blower motor resistor twice!
    Would anyone know what if i have a wiring problem?
    What do i look for?
    Where do i start?
    Thanks in advance for your help.
  • efv921efv921 Member Posts: 2
    edited March 2010
    I have a 2001 Quest w/ same issue, went through 3 resistors b4 asking my Nissan parts guy who suggested that the blower motor itself was bad (bearings go) changed it and solved problem. Bought new from dealer parts for @ $115. Hope it helps. PS- The motor is right next to the resistor and you have to reuse the fan blade, and you need a new resistor, you can buy those from auto parts store for @ $40. B sure to disconnect battery when installing both parts or you may blow fuses.
  • canyonsvocanyonsvo Member Posts: 23
    how do you make a new topic on here?
    Details are in the FAQ.
    Steve, visiting host
