Jeep Wrangler Transmission Troubles
13567
  • tjse7entjse7en Member Posts: 1
    I can tell you all already I miss my 99 cherokee sport... anyway, I got A 2008 wrangler unlimited. 902 (pampered) miles.... check engine light already on... any ideas? Also, is the slight vibration in the steering wheel the newness, and is the engine so noisy?
  • mohrlingmohrling Member Posts: 9
    I just had my '88 restored with a reman engine, new clutch, etc. This Jeep sat in my garage from 2000 until now. My mechanic can't get it to engage any gear and is worried about the transmission. Unfortunatly he's not a transmission repair guy and it's off to another shop. Any thoughts?
  • mac24mac24 Member Posts: 3,910
    Highly unlikely to be the transmission. It's almost certain that the clutch friction plate has become stuck to the flywheel. This is very common on manual transmissions that have stood for several years, or sometimes even just a few months if it's in a damp environment.
    There's also an outside chance that clutch hydraulics may have leaked, but that can easily be seen and felt.
  • mldeandamldeanda Member Posts: 1
    I am thinking of buying a 2000 Wrangler Sport with a 5spd, only 64k on it. Transmision seems to pop out of first gear while takin off or......when it gets warmed up or there are more than one person in it it will not pop out. Otherwise it shifts fine. My boss (the owner of the Jeep) is around 400 lbs and when he drives it, it has never popped out of gear for him. If anyone can help that would be great! Please email me for the quickest reply. mldeanda@hotmail.com
    Please email me for the quickest reply. mxxxxxxa@hotmail.com
    First, it's really not a good idea to post your email address in a public forum.
    Second, the idea here is for everyone to be able to benefit from the questions and answers. Taking it to email makes that a little difficult.
    Third, it's a known issue. I'd guess that the reason it doesn't jump out with your 400lb boss driving, or with a bunch of passengers, is that the gears are being held in mesh due to the heavy load on them.
    The fact that it will also stay in gear when the transmission is warmed up, and therefore when the lubricant is thinner and less viscous, indicates that changing to a synthetic oil might provide some temporary relief, though it won't be a permanent fix.
    So, either negotiate a reduction in price to allow for the transmission to be fixed, or an increase in wages to achieve the same, or plan to put on several hundred pounds over the holiday. :)
    The mechanic had replaced the flywheel and installed a new clutch. It was a real headscratcher. I took it to the transmission shop and they said nope...but they were able to get it out of neutral and through all of the gears. But when it warmed up then another crazy noise was heard in the front part of the engine. It was a pretty bad knocking that sounded a lot like ignition pre-fire but wasn't. I had it towed to the eingine shop, the place that sold the motor to the shade tree mechanic that installed it and everything else. As it turned out the shade tree guy didn't compress the harmonic balancer enough, he used the wrong bolts somehere arounfd the timing chain and the belts to pully to alternator wasn'rt aligned properly. My new shop said they couldn't believe how loose stuff was. Anyway got it back running after 9 years.
    Glad to hear you have it running again (and always beware of the shadetree mechanic!). :)
  • nomad443nomad443 Member Posts: 10
    Help!
    Purchased a 2004 Wrangler Sahara, 4.0, 5 speed, in April this year, 24,000 miles. Carfaxed it and it was clean. Car dealer replaced the ring & pinion for me. My question is what causes the transmission noise (?) when the clutch is released? When the clutch is depressed it stops. How to describe it? Grinding may be too harsh. Vibratiing? Chattering? The mechanic at the used car dealer claims it's the meshing of the gears. The service manager at the local Jeep dealership said the same thing. He even said the "new ones do it". Is this something to worry about? Is this American quality? Or is it "just a Jeep"? Thanks for anyone's input.
    nomad443
  • alskdjfhgalskdjfhg Member Posts: 1
    I have a 88 wrangler with a 6" lift, but the transmission was never lowered. I recently broke the u joint straps twice in the last month, and will be switching to a new yoke and u bolts, but when I tried to drive home with the just the front wheels engaged it kept popping out of 4 wheel. I am worried that the worn yoke and broken straps may have to do something with the tranny too, not just the lift with no dropped tranny. Maybe too much vibration?
    Any ideas? Thanks.
    Yes, I suspect the vibration from your wildly misaligned propshafts is causing it to jump out of gear.
    You need more than new a new yoke and 'U' bolts, The straps are breaking because they're being overloaded. If the 'U' bolts are strong enoughto remain intact then the 'U' joint will be the next to break.
    Go HERE for a good explanation of your problem and how to fix it.
  • jtmathmanjtmathman Member Posts: 1
    My transmission is hard to shift, especially when it is cold. It ets somewhat easier when the motor warms up, but even then its hard. Any suggestions?
  • roadburnerroadburner Member Posts: 18,616
    Your transmission may be filled with the wrong type of gear oil. I suggest that you drain it and refill it with the correct oil.
  • erickplerickpl Member Posts: 2,735
    Redline MT90 (manual) or MTL90 (automatic) are good choices. So is Royal Purple.
    -Paul
  • ebessebess Member Posts: 1
    I have a 98 4clyinder 5 speed and was driving on the highway in 5th the other day when the gear just went out. All other gears work but I get nothing in 5th. No prior problems with the transmission, replaced the clutch in December 07.
    Have I burned the gear up or is there a possibility it's something else?
    Whatever happened, it can't be fixed without removing and dismantling the transmission.
    If there's no additional noise from the transmission the cost of parts will likely be minimal, but the labor cost will be the same whatever the cause.
  • hank25hank25 Member Posts: 3
    My son drives a 95 wrangler 4 cylinder 5 speed. When leaving work the other night he said he had trouble getting it to shift out of second gear. When it did come out, he said it "popped" out and now it is stuck in neutral and will not go into any gear. Any idea what the problem might be? Now he is driving his mothers car to work and she's not happy!
    Like the previous one, if it's a transmission problem then the transmission will have to be removed to fix it.
    However, it's possible that it's a clutch problem, with the clutch not disengaging.
    Will it go into any gear with the engine off?
    Sorry it took me so long to get back to you. Since I am not a mechanic by any stretch of the imagination, I have no idea other than pulling the tranny and having it checked out. I'm still hoping that someone can give me a good guess as to what's causing the noisy vibration when the clutch is engaged. I've been told by two service managers that it's nothing more than the gears meshing and that even new ones do it. My question to Chrysler would be "IS THIS JEEP QUALITY????" I had the ring & pinion replaced at 24,000. Thank God the used car dealer paid for that. Good luck with your son's problem.
    mac24,
    Tried what you suggested. It will go into any gear with the engine OFF. If it is just the gears meshing, it's just disconcerting that a vehicle with 27,000 miles (now) would seem to be such poor quality and makes all this vibration noise. Gee, having grown up in the muscle car era and having owned 3 GTOs, a 455 T/A, and a '64 Corvette, none of these cars ever had this problem.
    Thanks again for your help.
    nomad443
    Hi nomad443,
    I was actually replying to post #124 by hank25. Looking at your original post #115, it sounds like the classic symptom of a bad transmission bearing, probably the one on the input shaft.
    When the clutch pedal is depressed the input shaft is disconnected from the engine and stops turning. However, whether it's the bearing or the gear itself, the transmission has to come out to examine and replace it.
    Two points, if 'they all do that' challenge the service manager to demonstrate it to you on a new Wrangler; and I'd question how gentle the first 24K miles were if one of the axles required a new r&p.
    No. even when the engine is not running it still will not go in gear. It does go side to side like it should but not front or back into gear.
    mac24,
    Thanks for your input. I'm going to visit our 2 reputable 4-wheel shops in my area and run your diagnosis past them before I visit the Jeep dealer service manager who gave me the gear-meshing bull. You sound pretty much like you know what you're talking about, so what is your experience with Jeeps, if you don't mind telling me? I'll probably refer to you in my discussions. Don't really need your name. Probably mentioning Edmunds will suffice. Thanks again for your help. Sounds like I might need to put out some serious bucks.
    nomad443
    I had another guy that works on transmissions tell me that it sounds like the synchronizers went out on it. He said I'd probably be better off just finding another transmission.
    The synchronizer rings, or synchros as they are often called, grab the spinning gears and allow then to match speeds so that they can mesh smoothly as you change from one gear to another.
    The syncros have no effect when the gears are stationary, so whether they're good or bad it'll make no difference to gear selection with the engine off.
    It's also highly unlikely that the syncros would fail on all the gears at the same time.
    Your transmission should be an AX5. If you can get another one that's in good condition, great. If you get one that's worn though, you're back to square one.
    Once you've established whether the noise is excessive or not you can go on to fixing it. There is an outside chance that it's the release bearing, which will require transmission removal to replace it, but not the stripping of the transmission itself.
    However, the normal problem with the release bearing is the other way around, noisy under load and quiet when released. It does happen backwards sometimes though.
    However, the most logical diagnosis is that it's an internal transmission issue, either a gear, shaft, or bearing (or possibly even a lack of lubrication). While idling in neutral a limited number of parts are rotating, with the clutch pedal depressed none of them are rotating, so the noise stops.
    This isn't specifically a Wrangler problem though, it can happen with any manual transmission on any make or model. The fact that you have this issue, coupled with the need for a replacement ring and pinion in one of the axles, suggests that your Jeep may have previously led a hard life.
    My C.V. is immaterial really, I never claim to have the definitive answer to anything, and any advice you get here is only worth what you paid for it. However, if what I've said makes logical sense to you, then it gives you an understanding of the problem that you can comfortably discuss.
  • legendmfglegendmfg Member Posts: 1
    I have a 95 wrangler with a bad tranny. It is a 5 speed and I wanted to know if a 5 speed from a 89 or 90 will fit. I have been told that everything is the same except for the bellhousing. If the input and output shaft are the same could I use the bellhousing off my 95 on the 90 transmission.
    legendmfg,
    Sorry. I'm not a motor-head by any stretch of the imagination. Just a casual driver who has a a Jeep for summer cruising and a spare 4-wheel drive for the Winters in PA. Sorry I can't help you out.
    nomad443
    mac24,
    Thanks for your response. One 4-wheel drive shop diagnosed my problem as a needle bearing. As of now I'm in the process of replacing the tranny thru another 4-wheel shop in our area. Funny your response should come today. Got a call from the shop today and when they put the new one (supposedly brand new NV3550) and ran it the noise stopped but it popped out of 1st gear more than once. They called and are having another sent. It's coming from Blumenthals (?) in the mid-west. Supposedly a reputable shop they've dealt with for years. So I guess we'll find out. Thanks again for your input.
    nomad443
  • apgarmelapgarmel Member Posts: 2
    Hi- brand new wrangler (owned many jeeps, never a wrangler) only has 500miles and it seems to shift really odd....accelerating onto the highway, it goes up to 6,000RPMs in order to shift and accelerate....at 70mph it noticably shifts and the rpms jump from 2-3....i have never driven a vehicle that shifts at this speed (at least to the point where I notice the rpms shift).....It feels like the pedal is stiff, but i am convinced that isn't the issue....please help...I am in love with this thing, but I bough new so I don't have to deal with this crap...thanks! :cry:
    Is this an auto or manual?
    You reference the vehicle shifting at different speeds and rpm, but you also mention a pedal feeling stiff.
    Bottom line, it's under warranty so take back to the dealer to fix.
    Auto...sorry for the confusion....it feels like the gas pedal is stiff, but it definitely has a different way of shifting than my 99 Cherokee did...if it is just a difference between cherokee and wrangler...I am cool but I feel like it isn't....I am having them install a hard top in a week or so, will definitely mention it. Thanks!
  • porterzporterz Member Posts: 3
    My brother in law is having trouble with his jeep.. Im stumped. The jeep seems to shift decently till you hit 4th. Upon hitting the clutch and shifting out of 4th though.. its stuck.. wont shift to any gears.. moving or stopped. It also wont shift into a gear until the clutch is pumped. This seems to reset the tranny and then you can shift into any gear. If the jeep is turned off while the jeep wont shift.. well then you have to turn it back on and pump the clutch to get it free. Just curious if anyone has any ideas before I tear it down.
    Jeep drives well, but wont shift up or down a lot. Seems to lock the tranny from shifting. After driving it.. it shifts up well.. and will often shift all the way to 5th. But 4th is very problematic. Once 4th is engaged the jeep loses its shifting ability. It literally will not go into any gear moving or not with the clutch down. If you release the clutch and pump it, there is a clunk, and you can then shift. Parked the jeep will run through all the gears.. off it will run through. If the problem occurs and the jeep is turned off it remains unable to engage a gear. Curious what could knock out all the gears.
  • rube5rube5 Member Posts: 2
    At 29000+miles, my Rubicon 6-speed neutral gear began vibrating with an annoying sound. This sound is quieted by depressing the clutch and/or slightly moving the shifter. The transmission was replaced but the sound continues. I now have 31000+miles on the odometer. I have visited three different dealers: #1replaced the transmission#2replaced Transfer case shift rail torque bracket#3Originally, recommended the replacement of the throw-out bearing and pilot bearing. I did this and it cost me almost $500. I returned and I was told that the noise is normal due to gear lash between input shaft and counter shaft. No problem found. I would appreciate any insight from other owners. Thanks in advance.
    Ok have now replaced the clutch and throwout bearing.. still have the shift issue. It only happens on the down shift.. and only in the 3 4 slot. At this point Im leaning towards the 3 4 shift fork. It tries to engage the gear, and then hangs up and wont shift to any gear then. if you skip 3 and 4 and go from 5 to 2 there is never a problem. Anyone else had a problem or heard of a problem similar? With the clutch depressed there is a noticeable rattle when it wont engage. Stopped when you release the clutch it also causes the jeep to lurch slightly and then disengages the gear. If you park with the clutch in and unable to shift upon turning off the jeep you cant drop the clutch for the reset.. it still wont shift. But with the jeep off it shifts perfectly every time. pls someone offer some help?
    rube5,
    I completely sympathize with you. It drives me nuts! I took my 2004 Sahara (28000 miles) to 2 local 4-wheel shops. One said he thought it was a needle bearing and would only increase in noise level but would not be a major problem. Had the tranny (NV3500) replaced at the 2nd shop, plus the throwout bearing. Seemed tight for about, oh, 2 weeks. Shifts fine, but noisy at shutoff. I think it's a Jeep tranny thing. One replaced is guaranteed for a year, so we'll see what happens.
    Please excuse the fact that I'm not a motor-head by any stretch of the imagination. Just have a Wrangler for summer rides and extra 4-wheeler for winters here in PA. Hope somebody has better info for you.
    nomad443
  • 06jeepunltd06jeepunltd Member Posts: 1
    Bought a brand new 2006 Wrangler Unlimited (my 3rd new Jeep Wrangler) and have had a problem with the transmission when the weather begins to get cold. Symptoms are, when temp goes to around 50 degrees (and car is still cold from start-up) there is a problem when I stop and begin to accelerate. The downshift to first gear is not immediate (2-3 second lag) at which time you can feel the trans re-engage and all is well until the next stop, although when very cold there is sometimes an abrupt hard upshift from from first to second. In late spring, summer, and early fall all is well which makes me believe temperature is the contributing factor here and not a mechanical one, as the transmission is smooth shifting and normal at all other times. When I returned my customer rating sheet to Chrysler noting the problem, I was contacted by their engineering staff and they seemed to know about this. They were familiar with these symptoms which lead me to believe I was not alone with this.
    My question is; is/was this a problem that led to a service bulletin fix such as software corrections. My Jeep has only 11,000 miles and is still under warranty and there is no sign of problems with the fluid. I am reluctant to have transmission pulled because of this intermitant problem which I can live with. Thanks
  • thegrlfrmtahoethegrlfrmtahoe Member Posts: 1
    So, maybe a couple weeks ago, I noticed a sound. The only way I can describe the sound is either like when mud dries and flies off your undercarriage while you're driving or maybe like a rusty bolt rolling around in the back. I wrote it off as something like that, until I cleaned everything out, checked underneath and didn't find anything loose, and the sound hasn't stopped...
    Fast forward to a couple days ago, I notice that I'm super sluggish when accelerating from a stop, like there is absolutely no torque. Once it catches second its fine, and it's fine at cruising speeds.
    I don't know if the sound is connected to the issue or not; Lord knows with the luck I've had lately, the whole bottom is probably about ready to fall out of it. I'm just hoping I don't need a new transmission. Any ideas?
    Sorry, I'm just a driver and not a mechanic by any stretch of the imagination. Had a '98 Sahara before trading up to a '04 Sahara and never experienced anything you've described. My only suggestion would be to take it to a REPUTABLE 4wheel shop and get their take on the problem. Good luck!
    nomad443
    When was the last transmission fluid change?
    Perhaps a fluid change with some good fluid would help.
    -Paul
  • randy0730randy0730 Member Posts: 1
    I have an 04 Wrangler. it is not very good on the highway as it continues to shift in and out of 4th gear. I have the 4.0 engine and the tires are not very big 31 x 10.5 x 15. the mileage on the jeep is 61K. Compression is good in all the cylinders. But going up average hills on the interstates (Alabama) it will shift down into 3rd at 60 mph. Is there an auto 5 speed that will rectify this or what is the next step/move?
    rc
  • long44long44 Member Posts: 3
    i own a 1987 jeep wrangler laredo and i have been having a really bad leak in my transmission , it pours ATF all over the ground and i have tried replacing the gasket on the pan and that didnt work, any one have any experience with this?
    i have a 1987 wrangler and i have the auto trany, it has been leaking ATF like crazy so i replaced the gasket and it didnt help, any sugestions
    I haven't done it myself, but I understand that positioning the gasket properly is VERY critical. And if there is any warping of the metal, you have more serious problems.
    SUVs and Smart Shopper
    It would also help if you said from where on the transmission the fluid is leaking.
    There are many other places besides the pan joint that it can appear from.
    well i pulled it apart yesterday and realized now that it leaking from the linkage rod on the top of the tranny, i pulled the rod off the get to the seal and when i hooked it back up now it wont shift at all and it wont even start. :mad:
    The noise upon shutting off the engine, I can live with. I believe it is a "Jeep thing", but the noise in Neutral gear is annoying. Thanks for your reply.
  • rootsarfrootsarf Member Posts: 1
    :confuse: I have a jeep wrangler 2000 with transmission problem, I need to know if the transmission from a 6 cylinder same year is compatible.
  • rokabilyrokabily Member Posts: 1
    i have a 2001 sport with 66,000 5 speed tranny.i just replaced the master and slave cylinder with factory parts but the problem remains the same .whenever it gets hot the clutch will not fully disengage so i have a lot of trouble getting it in and out of gear but if it sits over night its fine until it gets hot again
  • papparonpapparon Member Posts: 1
    I just purchased an '03 Saraha, 5-speed, 6 cyl.. I drives great, no jumping out of gear, shifts smooth however, it sometimes (about 50% of the time), sounds as though the throw-out bearing is going out. When I 'm stopped and engage the clutch the noise quits. Throw-out bearing, right? I had two very good mechanics who both had similar jeeps, look and listen to it. Naturally, it didn't make a sound.
    They both told me that my year(s) and model jeep are notorious for tranny noise and not to worry too much about it. Back in 1991 I owned a brand new GMC with a 5-speed standard tranny with almost identical sound problems...the GMC mechanic told me this: It's an aluminum transmission box that resonates sound more than cast iron, the gears have much closer tolerances than the old transmissions and because needle bearings are used, automatic transmission fluid takes the place of 80-90 all purpose. Thus more noise will be heard. He cured the problem by draining a pint of auto trans fluid and added some "Morley's" stabilizer.
    Has anyone heard of doing this with the Jeep transmission or adding a Lucas or some other brand stabilizer?
