Jeep Wrangler Transmission Troubles
I used to have a civic manual and I can do heel-toe downshift very easily.
With my current wrangler, the brake pedal and accelerator pedal is kind of too far away vertically.
(not horizontally)
So it is kind of hard for my right foot to control both of them at the same time.
Any tip, suggestions?
(not horizontally)
The AX-5 is a decent transmission for the 4cyl, albeit a bit weaker than the AX-15 found in the 4.0L engined Jeeps. But it is reliable in my experience.
I had no power in 5th gear either, but 33's will do that. So I regeared to 4.88.
-Paul
-Paul
Your dealer sounds like they suck. I cracked the windshield on my o7 and took it to the dealer for that, the recall and tsb for transmission and they gave me a free rental car. Your dealer was wrong and you should call chrysler and explain to them you are not happy and not taken care of properly. And for the don't buy american part, its pure opinion not fact as the toyota camry has had more transmission problems than they can count.
ALL first builds from ALL manufacturers have, to be nice, 'teething troubles'. In reality, the first purchasers are always the last stage of product development and reliability testing.
The problems you shouldn't be having are those associated with original dealer.
Finally, "...I guess I've been lucky. I buy a new car every years and have never had anything go wrong within the first year.........". I guess you have been lucky!
As far as likes/dislikes: I kinda wish I had the Sahara instead of a loaded X with S package (means just like Sahara except you get the Sahara's standard 17's and no YES! seats) because I think it would be nice to have the Yes seats, but so far haven't had any need. Have you decided on a top yet? The softtop works for me in snowy ohio, once you get the hang of it its easy to use. The only thing that needs improved is my gas mileage which is a measly 17 mpg, but i think i broke it in too hard and others have recorded better. Go for it!
This is a commonly reported problem if a body lift, motor lift, or suspension lift was installed.
I would look at the linkage under the body and make sure it is all good, and I'd check to see if the transmission mount is bent, damaged, or broken.
-Paul
True, but the usually reported problem is with the t/c rather than the main transmission. Most manual transmission problems that occur when the relationship between the transmission and the body has been changed, are concerned with an inability to engage a gear because the gear lever strikes the hole in the tub or the console.
I have a Tuffy console, with a bigger opening than the stock console, so it has never been a problem for me.
-Paul
Almost certainly, though it can be rebuilt.
Transmission will need to be stripped and rebuilt, but you may be lucky in terms of damage if there weren't too many expensive noises and you got it stopped quickly.
Take the opportunity to change the brass synchro rings while you're in there, and replace the clutch unless it was done recently. Of course, that's not quite so important if the labor is your own and you enjoy pulling the tranny.
GL-3 and GL-5 specification oils are used in manual transmissions.
ATF+4 spec transmission fluid is the only fluid to use in Wrangler automatic transmissions.
Dexron fluid of any spec should never be used in a Wrangler transmission.
It's a 1992 Jeep Wrangler YJ with what I beleive is an AX15 transmission. 5 speed manual.
The service center which just did the transmission flush ~3.5 months ago put in the Havoline Dexron IV fluid. What damage can happen with the Dexron fluid in the transmission?
I just started hearing the whining about 2 weeks ago. This was also after I had put the Jeep into 4WD(high) due to some adverse road conditions (snow, slush, ice) The Jeep has been used primarily for highway miles (~2,000 per month) since October 16, 2006
You must use a 75-90 GL-3 or GL-4 gear oil, or a synthetic that meets the same standards (Redline MT90 springs to mind).
An ATF (like Dexron) is required for the transfer case, but definitely not your AX-15.
ATF doesn't have the same shear resistance as a gear oil, so it could be wear on the gears themselves, rather than the bearings, that you're hearing.
When incorrectly using a GL-5, the greater sulphur content has an adverse effect on the brass synchro rings which causes baulking and noisy shifts.
I have a 2007 Jeep Wrangler X with an automatic transmission. I started having problems with it on 12/24/07. I heard a load "clunk" when I was driving that evening. There was no further noise, so I kept on driving. When I stopped and put it in park and then tried to shift into reverse the gear shift didn't want to move. I tried a second time and managed to get it in reverse. For a short time (maybe a minute) I heard kind of a grinding noise. Then the noise went away and I was able to drive home with no problem. When I got home I tried putting it into reverse and backing up. It was a bit noisy when shifting into reverse, but didn't stick as it did earlier.
I took my Jeep to the dealer, who checked it out and couldn't manage to recreate the problem I had. I drove my Jeep home and had no problems until the following day. When I tried shifting into reverse and stepping on the gas, my Jeep didn't move. I put it back in park and tried reverse again. This time there was no problem. After driving a short distance and parking my Jeep for a few minutes, I tried backing up, this time with no problem. However, after driving forward about 20-30 feet and stopping, I stepped on the gas and my Jeep didn't move. I moved the gear shift up to neutral, then to 2nd, back to drive -- no change. I shifted to reverse and back to drive and was then able to drive home.
My Jeep is currently at the dealer's and again, they can't recreate the problem. They seem to be trying to solve the problem, but haven't been successful, yet.
Has anyone out there had this type of problem with a 2007 Jeep?
Try printing it and taking it to the dealer and ask the service writer to give it to the tech. That way, he knows exactly what conditions were and the results. This will be way more valuable to him than the service writers description (which might say only "trouble shifting").
Terry
I can tell you that I have the Wrangler now in another shop for an opinion. The first shop (a dealership) indicated that a complete transmission was required, but could not produce anything to substantiate it. I asked for a sample of the transmission fluid (with the metals in it) and it was not available. They could also not tell me if the metal they saw was steel or brass. Also they suggested a new disc plate for the clutch may be a good thing to change out with the transmission. It was at that point that I decided to get another opinion.
I will tell you as a rule, I make sure that the problem description on the service ticket is to my satisfaction and that I get the service manager or tech (or both) out in the car to hear or feel the problem whenever I nees the car serviced for something other than routine maintenance. I will keep my information going in this post a developments continue -provided they add to the forum.
Finally, I am thinking of trying another transmission flush and ensure that the correct fluid in put into the vehicle to see if that clears up any of the whining sounds.
I just picked my Jeep up this evening since they still couldn't recreate the problem after trying for 3 days. I even tried to get the problem to occur before I left the dealer's lot. Of course, I couldn't get it to happen. I drove home with no trouble and -- you guessed it -- the minute I pulled into my garage I had trouble with it again.
This time drive seemed to disappear momentarily, then came back and my Jeep lurched forward. Luckily I didn't hit anything. I guess I'm going to try calling the Jeep "800" number and have it towed in. Maybe if I don't try "playing" with the gear shift like I did the last time I had trouble, it will still be in failure mode when they look at it.
