Saturn Outlook Lights
how do you remove low beam bulb, on passenger side
The hardest part was threading the high beam connector thru the housing hole. I did this by first removing the high beam bulb, then opening the hood and threading a coat hanger wire thru the high beam port and out the side housing hole. I then bent the hanger wire end back over itself clamping the harness wire at the base of the high beam conn. I then gently pulled it thru the high beam port. From there it was simple to install the high beam bulb with qtr. turn and clip the harness conn. to it. The parking lt. and low beam are much simpler to connect.
THIS PROBLEM IS DEFINITELY A GM/SATURN DESIGN DEFECT WHICH SHOULD HAVE A RECALL DUE TO POTENTIAL FIRE HAZARD. One could easily make this a good law suit case against GM for continuing to ignore a potential fire hazard, and for charging their customers over $200.00 for a 1hr or less procedure to correct a design defect they created!
Happy Fathers day guys!
Please let me know you found the part number. You can also find parts at www.GMpartsdirect.com. Hope this helps.
Christina
GM Customer Service
I havent seen a recall for this on safecar.gov though?
Sarah
GM Customer Service
I've seen your posts on a few different threads, and will try to post in a few different areas to hopefully get in touch.
If you would like, we can look into recall or warranty information with the last 8 digits of your VIN, or can assist in working with a dealership to get any existing concerns diagnosed and resolved. Please send us an email at socialmedia@gm.com with more information (your name/Edmunds username, phone and address, the last 8 digits of your VIN and current mileage, and the name of your involved dealership).
Best,
Sarah
GM Customer Service
Hello! I have had my headlight going out. Changed the bulb and noticed the wiring was melted. Now the light is out again, after only a week. Can you help me with this?
I'd be happy to look into my resources here. Is your vehicle a 2009 Saturn Outlook (just wanted to be sure)?
Best,
Sarah
GM Customer Service
If you would like for us to help you locate a Saturn-friendly service center in your area, please send us your request and ZIP code to socialmedia@gm.com. Alternatively, you can search yourself by using GM's dealer locator.
Sarah, GM Customer Service
I attempted to replace the right front low beam bulb on my 2008 Outlook. I was able to get the wheel lining loose by removing the screws and reach inside for access. I replaced the bulb and just to be sure it was the bulb that was the problem, I turned on the lights. The light STILL did not come on. I thought maybe it was an issue of not being grounded properly so I attempted to insert it into the mount and found that, somehow, there harness had gotten hung up and is now too short to allow me to get the bulb back into the hole! Closer inspection revealed that the wires have burn marks on them leading me to believe that there may be other damage further up the harness where it is not visible causing an open circuit or a short. After reading many similar complaints such as mine I would like to know; Is this defect is being addressed by GM?
See this forum for more of the same:
saturnfans.com
Some of these customers seem to be getting the harness replaced at dealerships, like this one:
saturnfans.com
In another forum a service bulletin is mentioned:
saturnoutlookforum.net
"TSB #09-08-42-004 "Low Beam Headlamp Replacement/Diagnosis (Inspect Fuse, Bulb, Harness, Replace Harness and Fill Connector Cavity for Low Beam Bulb Connector with Nyogel Grease) - (May 29, 2009). Document ID: 2284787. Applies to models 2007-2009 Saturn OUTLOOK"
Please let me know what you can do to help me out. I really can't afford to replace this myself. This customer writes that they received a recall notice and a reimbursement form:
#23 of 37 Re: Recall for headlight connectors [paynski]
townhall-talk.edmunds.com
I will also send this reply in an email to the email you gave me.
Sincerely,
A Frustrated Customer
Anyone know of an actual recall on this?
We sure do, and we would be happy to look into this further for you. Please send us an e-mail at socialmedia@gm.com and include your VIN, current mileage, contact information and the dealer you prefer to work with. Also, please provide any information regarding the previous repairs you received to your harness. We look forward to hearing from you soon!
Patsy G
GM Customer Care
We truly apologize for these concerns involving your Outlook. As we are not experts in vehicle diagnosis, we rely heavily on the dealership to provide additional assistance to our customer's vehicle concerns. If you need any additional assistance connecting with your dealership or look into this further, please send us an e-mail at socialmedia@gm.com. Looking forward to hearing from you.
Patsy G
GM Customer Care
