Ford Expedition fuel pump problems
We purchased our 2005 Expedition 4 1/2 years ago and have enjoyed it. It has posed very few problems. About 3 weeks ago, we experienced problems starting the car, and our independent mechanic diagnosed it as a broken fuel pump. However, we cannot locate a replacement pump (Part No. 6L1Z9H307A) anywhere in the country. I called Galpin Ford here in L.A. (the world's largest) which told me that they will not be restocked with this part until February. No other dealers have the part, and can't get it to us for weeks. I have searched online with no luck. We tried a used part, but after it worked well for about a day, it ultimately worked no better than the broken one we pulled out. In the meantime, my family is dead in the water with an inoperable truck!
I understand that my situation is not unique. I hear that several local police departments have Expeditions that are inoperable because of broken fuel umps and no replacements parts. Government vehicles supposedly have priority to receive the parts first.
I cannot believe that a car as ubiquitous as a Ford Expedition cannot keep a supply of common parts among its dealers and suppliers. What is going on here?
There is some speculation that this may be a result of "cash for clunkers": the government has made it public policy that these large block SUVs are disfavored and their destruction will be subsidized, therefore the parts manufacturers will not make replacement parts for cars that are being forced off the market.
Does anyone know how to get ahold of this part quickly?
EJ
I also paid $650 to install a used fuel pump about a month ago. It worked only marginally better than the pump I replaced, but the truck still fails to start on occasion and is hardly reliable. Because the replacement pump is not completely dead, I am lead to believe that it was my pump and not the electronic controller box attached to it. My mechanic tested the used pump, and the test showed that the used pump had a faulty valve that does not always operate properly, which is different than the dead-dead-dead nature of the old fuel pump.
The point of my rant is this: Ford sold many, many units of this vehicle. It should not be so difficult to get ahold of a fuel pump-- a basic part, nothing exotic--for this vehicle. As much as I have enjoyed the truck, I am strongly discouraged from purchasing another Ford in the future if they won't even ensure an adequate supply of basic parts. This is not a Ferrari where you have to order parts from the Old Country. This is supposed to be a user-friendly truck. Turns out it is not.
As of 1/6/10, this in-tank pump was No. 16 of the Top 500 most back-ordered parts in the Ford catalog. It may be higher than that by now.
The Explorer is nice but doesn't compare to my Expedition. Good Luck!
Still no word on the availability of a replacement pump.
In any event, I wish you the best and hope you enjoy your new truck.
But thanks for letting me know, otherwise I might never have heard from my mechanic!
I pray this is the end of my parts problems with Ford. My wife has been cursing this car with the unreliable used fuel pump for weeks. I've had no peace...
This Expedition would not crank when cold, 60 degrees, it would crank.
There are two wires going to the fuel pump near the Left Rear tire. Key on,White is 12 v and black is ground. Make sure that the fuel pump is getting power or not with a test light. This can be checked at the module behind left rear tire, on top of frame. You can see it at the 2:00 position at the rear tire through the fenderwell. The plug is on the front side of the module. I had to lay under the truck to access this wire. A shield mounts the module to the frame. Two small screws hold the module on the shield and two more hold the shield on the frame.
Coming out of the fusebox is a Dark Green wire with a yellow stripe. This wire sends power out of the fusebox to the inertia switch to the fuel pump. If you have power at #12 fuse but none at the green/yellow wire, the relay is bad. This wire is on the top of the fuse box, towards the firewall and bottom left wire in the plug. Again, to replace this relay on this vehicle, you must change the fusebox.
Hope this helps.
P1235 P1233 and P0191. I then had it towed to the dealer who says my problem is related to the throttle. My question is, what should I ask them to look for? Is there any possible way it is related to Customer Satisfaction Prgram 07M08 where they have the injector problems with the 05 Expeditions? Mine is an 05 Eddie Bauer.
Please help!
Took to Ford dealership in Guntersville, AL. They told me I needed to replace fuel pump & filter for a total of $985 ($499.99 was the cost of the fuel pump part alone, seems high to me). A $1,000 later and it still won't crank. Then they tell me there is moisture in the fuse panel. That was yesterday at 5:00. Please pray for me this repair will not be another $1,000!!! Will keep you posted. Is there any help from FORD on this issue?
Trouper
Is this the sending unit causing the problem?
Thank you all for posting this thread and for your future communication.
In addition I have had an intermittent no start issues which shows up when no one is around to check it. The mechanic seems to think that the module was causing the fuel pump to not put pressure at the head and therefore not start. I back off the key and try it again and it always started and ran just fine. Just looking to get back on the road as fast a possible. I appreciate any help. Thanks
So then I'm nearly empty on gas so I go to the Chevron and buy 6 gals of premium and a Techron fuel injection cleaner (good for up to 14 gals it says) and dump that in. It hesitates on start - but definetly better.
This morning I drove it to work, started on try 2. I figure maybe the gas tank is really dirty and needs some sloshing around cleaning. I get to work and turn it off and then on 5 times. It starts with slight hesitation on try 1 all five times.
I think I'm on to something here - so I suggest others give this a try. Change the fuel filter and clean your gas throroughly.
Also when I bought the car the used car dealership guy told me it took regular. I am hearing all around that is not true so I probably have 5 years of build up.
I will update this post if this doesn't work - oh and a fuel pump at Pep Boys is worst case $450 he said. The dealer was having to use after market parts so what's the diff? Pep Boys has fixed lots of my cars over the years just fine.
Oh and my brother pointed out that if it was the fuel pump - starting to go out - after 6 months wouldn't it be gone by now?
