Merecedes Sprinter
sprinter2010
Member Posts: 9
This discussion is for the all new Mercedes Sprinter van.
Mr DJ
I have had several request for the 4X4 and am sending them up the chain to Mercedes. I hope they have them soon, as well as a 4cyl. option.
Which Sprinter Forum are you on?
waited a few seconds , and restarted. Then the symbols would go off and the vehicle
was fine . It would do this on and off maybe once or twice a day and of course as I'm driving along the brake system and handling would be off ? The past few weeks I noticed that when it would do what I just mentioned above and I corrected the problem by stopping and starting that the cruise control would not work ? So, when the ABS lights are not on the cruise control will work .
Today I just had the ball joints replaced and now the lights will not go off at all but the shift lever does not get stuck in Park? The vehicle has 216,000Mi and other than this it runs great. Can you help, greatly appreciated
SYMPTOMS
1. SPRINTER ABS, EBS AND OTHER WARNING LIGHTS COME ON.
2. CAN NOT MOVE SHIFT LEVER.
PROBLEM
BROKEN INSULATION POINTS ON TAIL LIGHT UNITS
First, warning lights come on (systems still work though)
Second, shifter will not move
Third, fuses will begin to blow in a series anytime you hit the brake pedal; followed by tail light bulbs
Lastly, nothing works
SOLUTION
Immediate:
To Move Shift Lever: - There is a pen sized hole located at the bottom of the lever selector.
(if you could pull the lever all the way down the hole will be on the left side of the selector with a shallow cover that you can easily see if you are looking for it.)
- Stick a pen in the hole and gently push down as you take the shifter out of Park.
- Every time you need to restart it just use the pen. No harm no foul.
THE FIX:
Took me a long time to figure this one out - but i go some help from a guy online.
It boils down to a simple loss of insulation on the tail lights.
Apparently, at about 65K, the tail light assemblies are notorious for some insulation falling off of them - which creates a series of shorts - thus the warning lights and shifter problems.
• Replace the lost insulation (I used cut pieces of strip ties)
• Replace any fuses.
• Replace all of the tail light bulbs.
• Go on your way.
SEE THE PICTURES THAT FOLLOW AS A STEP BY STEP FIX - YOU'RE WELCOME
(If pictures don't show -Email me and ask for them)
I have the stalling symptoms with ABS,EBS, and traction lights when I hit the brake pedal( stalls 1 out of 100 times), but so far have not found any bad wiring or lose of insulation.
cheers patfrey
I am looking to buy a used Sprinter for my business, but many are saying that it the parts are very expensive and seem to have breakdowns etc. Anything I should look out for while I am shopping for a Sprinter???
